Rover 216 GTI (new engine)
bhlegit
Re: Rover 216 GTI (new engine)
#16 Post by bhlegit » Wed Dec 27, 2017 6:15 pm
noprobs found this:
D16A8
Found in:
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992-1995 Rover 216/416 GTi(UK/Europe)
1993-1997 Rover 216 SportCoupe (Europe)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Compression : 9.5:1
Power : 125 hp (93.2 kW, 127 ps) @ 6800 rpm
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 5900 rpm
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 MPFI
ECU Code : PP5
Gearbox : L3
D16A9
(Same as D16A8 but without a catalytic converter)
Found in:
1988-1991 Concerto (UK/Europe)
1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
1989-1992 Rover 216/416 GTi (UK/Europe)
1992-1995 Civic Si (Japanese and Peruvian version)
Displacement : 1,595 cc (97 cu in)
Compression : 9.5:1 (p29 pistons)
Power : 137 hp (96.9 kW, 132 ps) @ 6.800 rpm
Valvetrain : DOHC 16 valve (4 valves per cylinder)
Redline: 7500 rpm
Limit: 7800 rpm
Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1)
ECU Code: PM7
GearBox : <non LSD> (88-91 L3) (LSD 92- 95 S20)
so defo want to stay with the original d16a9 engine
Club Secretary
#17 Post by Paul_1978_yorks » Wed Dec 27, 2017 6:49 pm
That sounds about right. My old 416 (SOHC) was pre-cat but my later 216 did have a cat.
bhlegit
#18 Post by bhlegit » Wed Dec 27, 2017 7:37 pm
So still looking lads! pls share if you see anything. Cheers
#19 Post by Mr Teddy Bear » Wed Dec 27, 2017 9:55 pm
That cabby is a M [95] It's the Honda DOHC with a Catalyst exhaust fitted. The earlier non cat engines have different valve timing and thus different cam shafts fitted according to my Rover [Honda] engine overhaul manual. That as far as I'm aware is the major [only?] differences between the engines.
bhlegit
#20 Post by bhlegit » Thu Dec 28, 2017 6:38 pm
yep of the 4 cabbys i managed to find all are d16a8 engines :( still waiting to hear about the gti's in the scrapyard
JOHNDQ
#21 Post by JOHNDQ » Thu Dec 28, 2017 7:32 pm
What scrappy you found a GTI in? Don't worry I'm not after a engine
bhlegit
#22 Post by bhlegit » Thu Dec 28, 2017 7:44 pm
@JOHNDQ one on ebay called becrow dismantlers who had a cabby up and i messaged him he said he also had 2 216 gtis (waiting to hear back), also theres another one but its offline i'd have to find the name again as have been calling around many
bhlegit
#23 Post by bhlegit » Thu Dec 28, 2017 7:44 pm
im also after drivers side rear quarter panel so dont cop that!!1 :)
bhlegit
#24 Post by bhlegit » Thu Dec 28, 2017 7:45 pm
and headlights and original radio. thats why ideally im looking for whole donor car with d16a9 then i can take other bits off it i might need
JOHNDQ
#25 Post by JOHNDQ » Thu Dec 28, 2017 8:49 pm
Thanks, no not after any of those bits did have a radio but unfortunately sold that few weeks back
Club Secretary
#26 Post by Paul_1978_yorks » Thu Dec 28, 2017 11:29 pm
Be interested to hear more about the GTis. They’re rare these days, and really shouldn’t be in scrapyards unless they’re shot to pieces.
JOHNDQ
#27 Post by JOHNDQ » Thu Dec 28, 2017 11:55 pm
I dont think they would be unless there rotten tbh
Club Secretary
#28 Post by Paul_1978_yorks » Fri Dec 29, 2017 12:40 am
Not necessarily. Seen plenty of perfectly serviceable R8’s in scrapyards because the owners either can’t be bothered selling them or they think they are worthless.
bhlegit
#29 Post by bhlegit » Fri Dec 29, 2017 7:39 pm
still no luck :( i think i have seen every cabby for sale in uk now *laughs*
#30 Post by richard moss » Sat Dec 30, 2017 12:14 am
If I remember correctly, the block from the single cam and twin cam D series engines is the same - so the head from the twin cam can be swapped over
