Rover 216 GTI (new engine)
bhlegit
Re: Rover 216 GTI (new engine)
#31 Post by bhlegit » Sat Dec 30, 2017 3:46 am
if thats so then that defo sounds like a plan. i need to have a look and see what else has been damaged. Havent checked in daylight since got towed back. Can anyone else second that, that the block is the same? thx
#32 Post by Mr Teddy Bear » Sat Dec 30, 2017 11:32 am
Hang on!
The SOHC and DOHC engines are completely or significantly different. Different C/R for a start, that suggests different crankshaft and con rods, possibly pistons? Look at the build order and part numbers on Rimmer Bros.
The engine less the head is more likely to be interchangeable between a D16A8 & a D16A9.
bhlegit
#33 Post by bhlegit » Sat Dec 30, 2017 2:52 pm
ok will havea a look
celica1600gt
#34 Post by celica1600gt » Sat Dec 30, 2017 7:07 pm
Checked with Haynes manual they confirm bar the head the engines are identical , so its sounds as though a block complete hunt is on.
#35 Post by Johnny 216GSi » Sat Dec 30, 2017 8:52 pm
Ys, the SOHC has different sized pistons and everything. I'm not sure anything will exchange between the SOHC and DOHC.
bhlegit
#36 Post by bhlegit » Sat Dec 30, 2017 9:15 pm
so depending on the dmg i could use a d16a8 block? but if theres any pistons or rods damaged will have to replace all with d16a9?
celica1600gt
#37 Post by celica1600gt » Sat Dec 30, 2017 9:56 pm
The haynes manual confirms the bottom of the engines are identical, i don't know never had one to bits but cc is the same . Surely somebody can confirm.
#38 Post by crepello » Sat Dec 30, 2017 10:54 pm
The blocks and pistons do have different part numbers between SOHC and DOHC on Rimmer's site.
bhlegit
#39 Post by bhlegit » Sun Dec 31, 2017 12:52 pm
maybe i could get a block from rimmer bros? see part LCF10052. i was considering getting a new body panel from them too. although it doesnt look like they have it in stock but as with the body panel i called up and they checked some stockists and one in Holland had it..
celica1600gt
#40 Post by celica1600gt » Sun Dec 31, 2017 3:53 pm
dohc engine on Facebook on rover r8 enthusiast page , could be solution to your problem.
bhlegit
#41 Post by bhlegit » Sun Dec 31, 2017 10:54 pm
hey thanks mate will find it now
bhlegit
#42 Post by bhlegit » Sun Dec 31, 2017 11:02 pm
hey was it the white one you were talking about? think its the sohc engine
bhlegit
#43 Post by bhlegit » Sun Dec 31, 2017 11:03 pm
can u link it? thx
celica1600gt
#44 Post by celica1600gt » Sun Dec 31, 2017 11:45 pm
Its on the rover r8 enthusiasts page , the post is made by a guy called daniel williams and he has a sohc 216 gti for which he has a spare dohc engine he was going to fit into it, so must be a honda dohc engine which he will sell.hopethis helps , engine is mentioned in the text for the white 216gti for sale , its in a cabby with 71k.
bhlegit
#45 Post by bhlegit » Mon Jan 01, 2018 12:42 am
yep nice one pal have messaged him about it. waiting to hear back
