Rover 216 GTI (new engine)
bhlegit
Re: Rover 216 GTI (new engine)
#46 Post by bhlegit » Mon Jan 01, 2018 12:18 pm
looks like this could be my option dudes! have spoken to the owner looks like il be able to get just the engine, and at 77k miles its only a bit over my 68k miles. With regards to swapping out the block and damaged rods pistons etc (i am no mechanic) does anyone know someone/somewhere that would be able to rebuild the engine in or around London? Cheers mates, and happy new year!
#47 Post by StubbornPatriot » Tue Jan 02, 2018 9:05 pm
bhlegit
#48 Post by bhlegit » Tue Jan 02, 2018 9:12 pm
hey thx for the link will keep that in mind a bit expensive though
#49 Post by 1234dist » Tue Jan 02, 2018 9:24 pm
:rolleyes
i need, i need, i need, i need,
found
Too much..
:slapme
bhlegit
#50 Post by bhlegit » Tue Jan 02, 2018 10:20 pm
:DD haha yeah I have messaged him though will see what he says. I think the guy with the old cabby engine was going to let t go for less if not free it seemed. Although this does look like if i got this i could get it sorted sooner rather than later :)
bhlegit
#51 Post by bhlegit » Tue Jan 02, 2018 10:24 pm
oh also its 199!! i read it as 999!! *laughs* will defo try to get a hold of this then
bhlegit
#52 Post by bhlegit » Thu Jan 04, 2018 12:53 am
hey guys it seems this one is a d16a8 too. Surely most of it is the same so could i use the block rods etc from the d16a8 to rebuild it? Apart from the cat converter are there any actual differences between the two? What should i do? Cheers lads
#53 Post by Mr Teddy Bear » Thu Jan 04, 2018 10:09 am
Right let's have a little recap because an element of confusion is creeping into the thread.
D16 Blocks
DOHC blocks have a water passage for the oil cooler fitted behind the oil filter, they also have a higher piston crown to achieve a higher C/R.
SOHC doesn't.
DOHC Cylinder Heads
The pre 1992 non cat' engine with a MANUAL TRANSMISSION was fitted with different camshafts [ valve opening closing and probably valve overlap differ]
For some reason only known to Honda, early DOHC engines fitted with automatic transmission have the same camshafts as later catalyst equipped DOHC engines.
This is an aside written into the cylinder head description on page 5 of the dohc section of the [Rover] Honda Engine/Gearbox overhaul manual. There is no mention of this in the Rover general vehicle overhaul manuals.
I can't comment on interchangeability, but it's usually best to change like for like. :slapme
bhlegit
#54 Post by bhlegit » Thu Jan 04, 2018 8:51 pm
slightly more confused now *laughs* :slapme i thought the a8 and the a9 were both dohc?
#55 Post by Mr Teddy Bear » Thu Jan 04, 2018 10:15 pm
Is your blown up D16A9 AN AUTO? because if so it's completely the same as the catalyst equiped D16A8
If it's a manual you will need to salvage your old head.
Club Secretary
#56 Post by Paul_1978_yorks » Thu Jan 04, 2018 11:19 pm
:rolleyes
found
Too much..
:slapme
Nothing wrong with shopping around.
bhlegit
#57 Post by bhlegit » Thu Jan 04, 2018 11:57 pm
no its manual
bhlegit
#58 Post by bhlegit » Thu Jan 04, 2018 11:58 pm
so i CAN use the a8 bottom and use my head?
#59 Post by Mr Teddy Bear » Fri Jan 05, 2018 11:02 am
That is the best option.
Keep the ECU matched to the correct cylinder head.
This keeps any subsequent fault finding within known parameters, because you have stayed with Honda's build order.
bhlegit
#60 Post by bhlegit » Fri Jan 05, 2018 8:32 pm
ok sounds good. My garage isnt a honda or rover specialist garage, do you think it would be a good idea to show them the forum post and the research i have done online re the engine and stuff?
