Rover 216 GTI (new engine)
bhlegit
Re: Rover 216 GTI (new engine)
#61 Post by bhlegit » Fri Jan 05, 2018 8:33 pm
or should it not be a problem?
#62 Post by Mr Teddy Bear » Sat Jan 06, 2018 10:34 am
I would try and source a copy of the Engine Overhaul Manual first and give them as much info' as possible.
bhlegit
#63 Post by bhlegit » Sat Jan 06, 2018 7:16 pm
i have bought the haynes manual - do you have a link for this engine overhaul manual or is it a section in haynes? thx
#64 Post by Mr Teddy Bear » Sat Jan 06, 2018 8:29 pm
I had a quick look this am on Ebay for my supplier, they have sold out.
Honda Engine/Gearbox Manual
I can photocopy either a] everything
b] just the DOHC engine section
and post if you wish, I shall need you to pay my costs and postage though. The P.O charges approx' 19P a sheet I think.
If you want a photo copy please PM me your address.
bhlegit
#65 Post by bhlegit » Sun Jan 07, 2018 9:40 pm
@MrTeddyBear i sent you a pm mate
#66 Post by Mr Teddy Bear » Mon Jan 08, 2018 1:18 pm
I haven't received it?
I have sent one to you use it to reply
bhlegit
#67 Post by bhlegit » Mon Jan 08, 2018 7:38 pm
https://www.carandclassic.co.uk/car/C914640
theres this one that we have looked at before but now has been reduced and it looks so similar to my engine that it must be the same! its a d16a8 engine so just wanted to confirm for sure if i can use the block from this engine? If so will use that as donor car and get new rods and pistons and engine completely reconditioned.
the price tag im looking at for different garages is rather a lot so if there's anyone on here with the skills, i would gladly rather pay an individual person than a company. Let me know cheers lads
Club Secretary
#68 Post by Paul_1978_yorks » Mon Jan 08, 2018 11:10 pm
Covering the reg number....because obviously someone is going to ring an R8 :S :laughing2
#69 Post by 1234dist » Tue Jan 09, 2018 7:36 am
I have rebuilt a Dohc before but I don’t have my garage anymore, but can happily talk someone through it.
bhlegit
#70 Post by bhlegit » Tue Jan 09, 2018 8:05 am
D16A8
Found in:
1988–1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992–1995 Rover 216/416 GTi (UK/Europe)
1993–1997 Rover 216 Sport Coupé (Europe)
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Compression : 9.5:1
Power : 122 PS (90 kW; 120 hp) at 6800 rpm
Torque : 14.9 kg⋅m (146 N⋅m; 108 lb⋅ft) at 5900 rpm
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 and OBD-1 MPFI
ECU Code : PP5 (OBD-0), P29 (OBD-1)
Head Code : PM7
Gearbox : L3
D16A9
(Same as D16A8 but without a catalytic converter)
Found in:
1988–1991 Concerto (UK/Europe)
1988–1991 CRX 1.6i-16 (UK/Europe/South Africa)
1990–1992 Ballade 160i-DOHC (South Africa)
1988–1991 Civic 1.6i-16 (UK/Europe)
1992–1993 Civic GTi (New Zealand)
1989–1992 Rover 216/416 GTi (UK/Europe)
1992–1995 Civic Si (Japanese, European and Peruvian version)
Compression : 9.5:1
Power : 125-129 hp (91.9-94.8 kW, 126-130 PS) at 6800 rpm
Torque : 105 lb·ft (14.5 kg/m, 143 Nm) at 5700 rpm
Valvetrain : DOHC 16 valve (4 valves per cylinder)
Redline: 7,200 rpm
Limit: 7,250 rpm
Fuel Cut: 7800 RPM (PM7)
Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1)
ECU Code: (P29 OBD1)
Gearbox: non-LSD (1988-1991): L3, LSD (1992-1995): S20
the 1991 d16a9 will be non lsd will the d16a8 block still fit to rebuild my d16a9?
bhlegit
#71 Post by bhlegit » Tue Jan 09, 2018 8:06 am
am i making this way more complicated than it needs to be, they are basically just the same engine?
bhlegit
#72 Post by bhlegit » Tue Jan 09, 2018 8:08 am
@123Dist I wish i had the mechanical skills to do that with you but i don't unfortunately :) Where are you situated, what about if i paid you a few bob check it over with my garage (they might not know this and that about rover/honda)? Im in London.
#73 Post by 1234dist » Tue Jan 09, 2018 8:17 am
i'm 260 miles away :slapme
#74 Post by 1234dist » Tue Jan 09, 2018 8:20 am
here's my last one :cool
https://ibb.co/album/h73Cov
bhlegit
#75 Post by bhlegit » Tue Jan 09, 2018 9:28 am
:O i need u *laughs* - damn ur so far away. so hard to find a garage that appreciates rovers, they all tell me to scrap it *laughs*. SO iv been told by one engine remanufacturing place that d16a8 and a9 block etc ARE NOT COMPATIBLE so now im even more confused. Im guessing the best route is to swap like for like I NEED to find d16a9 engine asap but looks like il have to play the long game.. :tumbleweed
