Jump Starting
cybercontroller
Re: Jump Starting
#16 Post by cybercontroller » Fri Dec 20, 2019 2:17 pm
Thanks, found it. May need to give them a go.
Continuing to monitor the clock situation as it came back again this morning.
So can narrow down to three possibly related, possibly not faults.
1. Battery may be past its best bur need to get checked.
2.Clock losing the display may be related or could be faulty without a battery problem. How easy is it to remove?
3. Heated rear window only working on a few elements. I suspect this is probably entirely a standalone fault now as I did not have cause to use it up until recently.
alviseven
Re: Jump Starting
#17 Post by alviseven » Fri Dec 20, 2019 10:19 pm
Whats wrong with one of the these solar powered battery trickle chargers
I use both powered AC mains ones and solar ones. You can extend the bell wire charge lead so the unit can be put on the roof of garage and leave the cable inside to hitch to the car. All my cars are battery isolated the moment they come into the garage and are hitched up to shore trickle chargers - makes the batteries so much longer lived.
Had one solar charger now for years - they were a Maplin Christmas present one year.
Twin G reg Red 216GSi Rovers
Re: Jump Starting
#18 Post by 1234dist » Sat Dec 21, 2019 7:17 am
In short, they don’t work.
If you want a trickle charger, get a smart charger.
Mine: https://rover.ebay.com/rover/0/0/0?mpre ... 3532642178
Best/cheapest: https://rover.ebay.com/rover/0/0/0?mpre ... 3278920310
Re: Jump Starting
#19 Post by ROVER-25X » Sun Dec 22, 2019 2:57 pm
If you want to be a cheap skate like me then get one of these from EuroCarParts, its only £21.55, I have two,
one of them keeps the battery for my cabby fully charged and its been off the road for almost 3 years.
