Replacing Radiator Core or New one
tonyinbeds
#1 Post by tonyinbeds » Tue Dec 10, 2019 11:31 am
Hi,
My 1600 Honda engined 216 is slowly losing coolant, not a major issue. Given the age and state of the radiator core it look like a few holes have rusted themselves into existence.
Rimmer has this https://rimmerbros.com/Item--i-GRID001099 I think I'm 2.
I've just inquired with a local Rad specialist as to cost of re coring v new one.
In the mean time was hoping someone has found a 1st class and cheap supplier of such items.... I can but hope.
Many thanks if you have a lead on possible source :blink
Cheers
Tony
1995 Rover 216 16V (Honda Engine)
Re: Replacing Radiator Core or New one
#2 Post by 1234dist » Tue Dec 10, 2019 12:04 pm
tonyinbeds
#3 Post by tonyinbeds » Tue Dec 10, 2019 12:36 pm
:clapping
Cheers
Tony
#4 Post by 1234dist » Tue Dec 10, 2019 2:46 pm
Please check it looks like yours before purchase
Club Secretary
#5 Post by StubbornPatriot » Tue Dec 10, 2019 10:45 pm
alviseven
#6 Post by alviseven » Tue Dec 10, 2019 11:20 pm
I have bought one of the Washington ebay based ones new but when they were a little cheaper - they have shot up over the last year or so. I wanted one that did not have sealed holes on the OS end of the rad as mine were leaking/weeping. But mine was £35 but then it was bought in 2016 - how time flies but same chap and part still perfectly in use 20K plus later
NOS one is more money even if no one bids if you include postage so know which I would buy!! :)
Twin G reg Red 216GSi Rovers
tonyinbeds
#7 Post by tonyinbeds » Wed Dec 11, 2019 12:41 pm
Thanks.
Having measured it I need a 522mm width one and looking at the number of fan studs on the Heathfield one it looks like a 400+mm one.
Cheers
Tony
tonyinbeds
#8 Post by tonyinbeds » Wed Dec 11, 2019 12:53 pm
Found this
New: A brand-new, unused, unopened and undamaged item in original retail packaging (where packaging is ... Read more
about the condition
Brand: Nissens
Dimensions (mm): 520 x 389 x 22 Country/Region of Manufacture: Denmark
First Fit (seals/fixings inc): No Manufacturer Part Number: 642161
Material: Mechanical aluminium MPN: 642161
Notes: WITH THERMO Other Part Number: HONDA: PCC001090E HONDA: 19010SK4E51 HONDA: GRD109
Cross-references: EAP8538 | EAP8721 | GRD125 | GRD931 | PCC10122 | 1 Part Manufacturer: Nissens
EAN: 5707286217768 Reference OE/OEM Number: GRD931 PCC001090E PCC10040 PCC10122 PCC104670
EAP8538 seems to be the Honda Part Number
https://www.ebay.co.uk/itm/Nissens-6421 ... 0005.m1851
Listed under a NISSAN...
Does anyone have the dimensions of the 522mm wide rad please?
Cheers
Tony
tonyinbeds
#9 Post by tonyinbeds » Wed Dec 11, 2019 1:05 pm
Cheers
Tony
