Part numbers for 1992 1.6 Honda r8
MGZRreplica
#1 Post by MGZRreplica » Mon Jan 27, 2020 7:45 pm
Every time I do a search on eBay and
Euro parts I get a choice of TWO or more.
I’m after the part numbers for
A j reg 216SLi Reg number J189OJC
Spark plugs?
Leads?
Dizzy cap?
Thanks for your time.
Re: Part numbers for 1992 1.6 Honda r8
#2 Post by Johnny 216GSi » Mon Jan 27, 2020 8:55 pm
Spark plugs?
Leads?
Dizzy cap?
Spark plugs - Rover part code: GSP-7662
After market - NGK: BCPR6E-11, or really fancy Denso Iridium: IQ20.
Leads - Rover part code: GHT-255 (Unipart)
After market: Bosch 721 (for example) E.g.: https://www.ebay.co.uk/itm/BOSCH-721-HT ... 4001739291
Dizzy cap - Rover part code: NJC10045
After market: E.g.: This one: https://www.ebay.co.uk/itm/Rover-200-21 ... 2528146923
I can sort out the Euro car parts references in an hour or two - right now I need to go somewhere!
MGZRreplica
#3 Post by MGZRreplica » Mon Jan 27, 2020 9:56 pm
Thanks again
I’ve just ordered the
Bosch leads.
You suggested.
#4 Post by Johnny 216GSi » Mon Jan 27, 2020 10:07 pm
Thanks again
Bosch leads.
You suggested.
They're a really good lead set - I've got a set of these exact ones too :)
#5 Post by 1234dist » Mon Jan 27, 2020 10:16 pm
Iridium plugs are only a requirement for the vvc but they do last longer in a normal k-series too. I think cost wise is 1 set of iridium to 3 normal.
#6 Post by Johnny 216GSi » Tue Jan 28, 2020 1:00 am
Thanks again
Bosch leads.
You suggested.
The "modern" Rover part references for these components are:
Dizzy cap: NJD100130EVA
HT leads: FDU2800EVA
Spark plugs: FDU2522EVA
The Honda equivalent part codes are:
Dizzy cap: 30102-PM5-306 (set that comes with the rotor arm too)
HT leads: 32722-PM6-B00
Spark plugs: Multiple options - these days just aftermarket parts given Honda part codes. Not sure what the difference between all these are, but the last 3 refs could be for the DOHC (216GTi) engine and therefore not applicable. The Denso reference is for their copper plugs - I gave the Iridium reference before and those do fit, as I have a set in mine.
98079-5614A PLUG, SPARK (BCPR6EY-N11)(NGK)
98079-56148 PLUG, SPARK (BCPR6E-11) (NGK)
98079-56158 PLUG, SPARK (Q20PR-U11) (DENSO)
98079-5714A PLUG, SPARK (BCPR7EY-N11)(NGK)
98079-57148 PLUG, SPARK (BCPR7E-11) (NGK)
98079-57158 PLUG, SPARK (Q22PR-U11) (DENSO)
Euro car parts:
Using your reg.:
1. The dizzy cap they have for sale doesn't look like the right part and the part code equivalences given aren't correct for your car as far as I'm concerned. I'd look elsewhere, such as the link I gave you.
2. There's 3 different ignition lead sets on offer, all with different part codes - but only one type in stock. There's no information regarding what these fit so again, I wouldn't buy them. Mute point anyway, as you've bought the Bosch ones now.
3. There are 7 different types of spark plugs on offer, but absolutely no information which of the two Bosch or four Denso ones correspond to what part numbers and therefore what's meant to be fitted to the car. You could possibly by the only NGK plug on offer and hope it's the right one, but again I wouldn't.
It's a pain as they've got an "up to 60% off" sale on, but I'd look elsewhere if the website can't tell you the right components for the car. It's a specific engine and the parts for these cars are very specific for each engine, so unless you can get confirmation possibly over the phone what each of their "product codes" corresponds to, just don't bother going through the pain of ordering and hoping everything will fit and then having to return everything. You might think you'll be getting a bargain with the 60% off offer, but you won't be in terms of absolute "bother."
Best prices I've found for your other parts:
Dizzy cap - £8 delivered: https://www.ebay.co.uk/itm/Honda-Civic- ... 3730943804 ("Ci parts" - new old stock).
Spark plugs: Set of 4 NGKs (as garages would fit) for £11 delivered: https://www.ebay.co.uk/itm/4-x-NGK-Spar ... 0830013103
Dorchester
#7 Post by Dorchester » Tue Jan 28, 2020 8:44 am
When I check your last reference:
"Spark plugs: Set of 4 NGKs (as garages would fit) for £11 delivered: https://www.ebay.co.uk/itm/4-x-NGK-Spar ... 0830013103"
they say it can be fitted on a 1994 216 convertible but not a 214 same year!
Is there any spark plug differences between those 2 engines Honda & Rover? :S
#8 Post by Johnny 216GSi » Tue Jan 28, 2020 4:28 pm
Two very different engines. The 1.4K uses NGK spark plugs part ref: BKR6E
