Expansion tank
G.Watts
Expansion tank
#1 Post by G.Watts » Sun Feb 02, 2020 8:19 pm
Hi all,after replacing the head gasket on my 45 I’m left with an oil stain in the expansion tank. Does anyone know of a product I can use to clean it ?
Re: Expansion tank
#2 Post by crepello » Sun Feb 02, 2020 8:34 pm
I took mine out, added a mix of engine degreaser fluid and small gravel, and shook it around.
The gravel took the muck off.
Kriss707
Re: Expansion tank
#3 Post by Kriss707 » Sun Feb 02, 2020 9:04 pm
Remove the Expansion Tank, block the hose holes, fill with hot water, drop in a Dishwasher tablet & shake vigorously. Rinse & replace.
Dishwasher tabs are also good for cleaning the water system before a Water Pump/Coolant change. Some people leave them in for up to 200 miles before changing to allow thorough system cleaning.
You must rinse thoroughly before refilling the system.
Re: Expansion tank
#4 Post by itcaptainslow » Mon Feb 03, 2020 2:56 pm
This is the best way-degreaser such as brake cleaner together with something like gravel to agitate and scrape away the oily film. You’ll be amazed how well it comes up!
Rover 200 BRM
Rover 214SEI
Re: Expansion tank
#5 Post by 961tat » Mon Feb 03, 2020 3:46 pm
Petrol and rice if they are realy bad , followed by dishwash tablet , no smoking :laughing2 :laughing2
G.Watts
Re: Expansion tank
#6 Post by G.Watts » Tue Feb 04, 2020 2:24 pm
I like that one :laughing2 I think I’ll go With the degreaser and gravel suggestion.Thanks to everyone for your lnput
Re: Expansion tank
#7 Post by ROVER-25X » Sat Feb 08, 2020 3:47 pm
I bought a new one, I kept looking and found one for £15 posted.
G.Watts
Re: Expansion tank
#8 Post by G.Watts » Fri Feb 14, 2020 3:58 pm
Just a quick update,I cleaned the expansion tank with degreaser and small gravel come up a treat but if like me you have a later vehicle with a low coolant level sensor it might be better not to use gravel as it gets jammed between the float and casing thus causing the warning lamp to either stay on or not work at all .I fixed it eventually but the small gravel chips were a devil to remove.
Re: Expansion tank
#9 Post by 961tat » Fri Feb 14, 2020 7:22 pm
Can't beat the later coolant expansion tank got them on all mine , bet your coolant look clean now :clapping
