Cooling fans running all the time
RoverTD
#1 Post by RoverTD » Thu Feb 06, 2020 4:10 pm
I have just noted that on y 2003 Rover 45 Diesel when I switch on the ignition, before actually starting the engine for the first time, the cooling fans start running even though this morning it was only 2 degrees C. On starting the engine , they carried on running, surely they should stay off until required ?
Re: Cooling fans running all the time
#2 Post by 1234dist » Thu Feb 06, 2020 4:11 pm
Cts has failed
RoverTD
#3 Post by RoverTD » Thu Feb 06, 2020 10:13 pm
Thanks for quick reply, can anybody advise where it is located and the part number . I have looked at Rimmers Site and doesn't define which is which
#4 Post by 1234dist » Fri Feb 07, 2020 11:01 am
https://rimmerbros.com/Item--i-MEK100061P
https://rimmerbros.com/Item--i-MEK000030L
https://rimmerbros.com/Item--i-MEK000030LP1
Its on the metal elbow that is bolted to the engine block, right side near airbox.
Just pick one of the above which looks like the one fitted
RoverTD
#5 Post by RoverTD » Fri Feb 07, 2020 5:42 pm
Looking at RAVE and Rimmers site , it looks to me to be ERR2081 for L series Diesel. Does that seem right?
RoverTD
#6 Post by RoverTD » Fri Feb 21, 2020 7:14 pm
I believe I have solved it. It would appear that having the aircon on, actives the fans even with the engine off, but ignition on. Switched off the aircon and fans stopped.
#7 Post by 1234dist » Fri Feb 21, 2020 7:18 pm
Never said it was an air con car...*laughs*
And what you using air on for, it’s winter.
#8 Post by montegoman » Fri Feb 21, 2020 9:06 pm
Yes, the fan stays on if the A/C is switched on. I believe that is the case on most cars.
#9 Post by richard moss » Fri Feb 21, 2020 9:19 pm
It dries the air and gives better screen demisting
