Engine won't start
dale214
Engine won't start
#1 Post by dale214 » Mon Apr 20, 2020 4:53 pm
Looking for advice.
Recently got my 214 sei back on the road after a few years lay up.
Started first time every time and ran beautifully.
After a couple of days the engine would cut out after idling comfortably at traffic lights.
Then it would be difficult to start.
After I left it 5min and a long spin on the starter it fired up.
Then a few days later it wouldn't start after a long run.
The engine was only stopped half hour so still hot!.
Got it going again and whilst driving it didnt miss a beat.
After not being a problem for a week it then starting running lumpy after starting.
It would clear then become lumpy again then clear all whilst driving.
Now it just wont start.
Have changed. Plugs.
Leads
Dizzy cap
Maifold and injection
Fuel filter
Am suspecting fuel pump in tank.
Any suggestions please.
Re: Engine won't start
#2 Post by crepello » Mon Apr 20, 2020 6:14 pm
It's usually possible to hear the fuel pump priming the system when the ignition is turned on. Does it sound dead?
Otherwise, crank angle sensors are know to die in intermittent fashion like you describe.
#3 Post by RoverRevival » Mon Apr 20, 2020 6:18 pm
I’d have gone fuel filter then pump as well, but you can test the pump buy taking the fuel feed pipe off the inlet and getting someone to turn key to position 2.
This is not a test for pressure only feed.
If it shoots out like you expect, on the other side of the fuel rail is the regulator. I’d suspect that next.
All above is assuming all rubber o rings are in usable condition and not pinched.
45 1.8 auto Connie 50k
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
dale214
#4 Post by dale214 » Mon Apr 20, 2020 8:32 pm
The pump does prime and fuel comes out of feed when tested. I wondered if the pump could be weak and not pumping at required pressure.
I was thinking about the crank censor next.
But what's annoying is that I have fuel and spark!
yet it will not start!.
#5 Post by crepello » Mon Apr 20, 2020 9:00 pm
Although I've never dismantled an internal fuel pump...
I think if there was a weakness on either stroke of the pump, it wouldn't reach the point where the switchgear requested a solenoid pull or solenoid release.
G.Watts
#6 Post by G.Watts » Mon Apr 20, 2020 9:15 pm
I had the same problem on my 214 a few years back not knowing if it would fire up or not.Sometimes it would be ok for a few days Then it would play up again.After replacing the crank sensor I never encountered any more starting problems.
richard moss
#7 Post by richard moss » Mon Apr 20, 2020 10:28 pm
I don't see rotor arm on your list of things that have been changed. They are a surprisingly frequent cause of ignition problems - and are cheap to replace
#8 Post by 220 GSi turbo » Mon Apr 20, 2020 10:31 pm
You haven't mentioned the rotor arm in your list of parts changed.
Although your symptoms don't match my experiences of rotor arm failure completely, it is a very cheap and very quick fix :)
Daily: ZR Trophy TD
#9 Post by Paul_1978_yorks » Mon Apr 20, 2020 10:43 pm
The last two posts took the words out of my mouth. When I ran 214 SEi’s as daily cars, I had rotor arm problems more than once. Cost about <£10 at the time to fix :)
1996-N Charcoal 214 SEi (project)
214 SEi x3, 216 SLi, 216 Cabriolet, 416 GSi, 25, 45, 75
#10 Post by 961tat » Tue Apr 21, 2020 12:04 am
Ive had these issue before and was convinced if was fuel pump related, start up and lumpy idle until warm , on the motorway started to die now and again , took foot of accelerator and then press down again all ok for 20mins , then started doing this again and over a period of time more often , rev limiter cut in at 5000 rev and it should rev to 7500 with ease on mine , then one day wouldn't start , changed crank sensor and runs perfectly 100% better than before :clapping , none of the above issue . The sensors can be checked but can still be faulty even if the check say yes , if its a old sensor as pointed out by a auto-electrician over the road . Type in The Halls effect . Basically the sensor as lost its magnetism .
Hope this helps .
dale214
#11 Post by dale214 » Tue Jun 02, 2020 11:34 am
Thanks for all advice given.
I changed the rotor arm spark plugs and crank censor.
But still would not start.
It has fuel and spark and timing is correct.
Immobilizer light goes out aswell.
After several days tinkering it suddenly started.
I ran the car for to two weeks with no problems.
Then it started cutting out at traffic lights again.
Yesterday it didn't start in the morning. After fiddling a bit it started .
Then later that day it would not fire so I had to walk home.
Im thinking immobilizer.?
Can i bypass it.?
Can anyone shed some light please.
#12 Post by RoverRevival » Tue Jun 02, 2020 12:49 pm
I can get you your eka code but I have to plug into the car so not really much help there.
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
dale214
#13 Post by dale214 » Wed Jun 03, 2020 12:56 am
I was told to press the lock button on my key fob 5 times with ignition on to release immobilizer.
Tried it and it worked. :clapping
Anyone heard of this before?
After reconnecting the battery i would lock the unlock car with the key.
Then i would turn the ignition on and press the unlock button once then lock twice and unlock once.
This would release immobilizer.
Which is correct?
Thanks.
#14 Post by RoverRevival » Wed Jun 03, 2020 8:30 am
Absolute croc....
More likely your fob just started working or was just low battery so needed to be in closer proximity.
There are only two (legal) ways of bypassing the immobiliser that I am aware of, the first being the eka code in the door lock and the other I won’t post on open forums.
25 Streetwise 54k
620 SLI Honda 60k
Yaris & C3
dale214
#15 Post by dale214 » Wed Jun 03, 2020 12:27 pm
The car failed to start again this morning.
Am I right in thinking that if the immobilizer light goes out on the dash then its all as it should be.?
