Battery negative lead (turbo)
T16-Tomcat
#1 Post by T16-Tomcat » Wed May 06, 2020 8:23 pm
Hi all, not sure if anyone can help, but....
I've completely rebuilt the engine and 'box on my T16 Coupe. It is now all completely clean and leak free, but somehow I've mislaid the battery negative terminal and main lead.
Is anyone able to confirm where the main cable on the negative terminal block goes to? I believe the main terminal cable his to a bolt on the nearside of the gearbox, then the engine loom and a couple of smaller body earth's connect to the bolt on the terminal.
If anyone can shed some light I'd be extremely grateful!
Cheers,
Kev
Re: Battery negative lead (turbo)
#2 Post by 220 GSi turbo » Wed May 06, 2020 10:34 pm
I'll check mine tomorrow afternoon and let you know.
Unless anybody else comes along with the info in the meantime :wink3
Daily: ZR Trophy TD
Cromp85
#3 Post by Cromp85 » Wed May 06, 2020 11:48 pm
I have just checked it on mine. :cool
Main cable from battery goes to a bolt on the front right of the gearbox casing.
Smaller cable from battery to earth point on slam panel (A few inches from battery)
Slam panel earth has two much thinner wires from the body loom, I think one is the fan but im not sure of the other.
1995 214i (On SORN)
T16-Tomcat
#4 Post by T16-Tomcat » Fri May 08, 2020 2:01 pm
Thanks! I thought that was the case. Now I can order the bits for a new one :clapping
Cromp85
#5 Post by Cromp85 » Fri May 08, 2020 6:14 pm
The negative lead from any R3 200 with a PG1 gearbox will fit, if you want to save a few £ :wink3
1995 214i (On SORN)
T16-Tomcat
#6 Post by T16-Tomcat » Sat May 09, 2020 9:08 am
How much do you want for it? Pm me if you'd prefer!
Cromp85
#7 Post by Cromp85 » Sat May 09, 2020 4:36 pm
It's in use on my car :laughing2
I paid about £5 for it along with a few other bits from a local breakers.
1995 214i (On SORN)
T16-Tomcat
#8 Post by T16-Tomcat » Tue May 12, 2020 5:16 pm
:laughing2
I read the battery negative lead from My R3 will fit!!
