cabby shocks and springs
#1 Post by 961tat » Mon Jan 09, 2017 10:47 pm
Hi folks
as anyone used f/k shocks as below from discount MG rover spares on offer at the moment , thinking of replacing all mind with new springs on 1994 214 cabby and they dont lower the car like a boy racer . :clapping
Rover 200 / 400 (R8) 89-97 inc Coupe Sports Suspension Dampers / Shock Absorbers - Full Set
Brand new set of Sports Shock Absorbers / Dampers for Rover 200 (89-95) / 400 (89-95) / Rover Coupe (91-98) models.
These are quality FK Germany items, priced to clear
This includes:
1x LH Front Shock Absorber
1x RH Front Shock Absorber
2x Rear Shock Absorbers
These items will firm up your suspension, and provide a subtle 15-20mm drop.
We recommend fitting these with lowering springs.
Re: cabby shocks and springs
#2 Post by 1234dist » Tue Jan 10, 2017 8:21 am
Charlzy and rick friends of mine have both got a set waiting to be fitted (bloomin rain)
Will be able to let you know shortly.
For anyone else who doesn't know about them £70 while stocks last:
https://www.dmgrs.co.uk/collections/bar ... s-full-set
#3 Post by 1234dist » Tue Jan 10, 2017 8:22 am
:glare side note, struts don't provide drop, it's the springs you use
#4 Post by 961tat » Tue Jan 10, 2017 6:14 pm
point taken , they should up date there imformation . :D
wha are you using on you cabby if you dont mind me asking ?
#5 Post by 1234dist » Tue Jan 10, 2017 7:12 pm
I'm on stock McPhersons. :cool
marcusdawg
New Forum User - Welcome them!
#6 Post by marcusdawg » Mon Apr 10, 2017 8:48 pm
Hi guys, recently purchased a 1992 216 Honda cabby.... I wanted to drop her bit. Not to much, just enough to not look like it's on stilts!!! Any kits worth recommendations?
#7 Post by ROVER-25X » Fri Apr 14, 2017 11:55 am
I got these for my Cabby, great quality. ;)
LINK: http://www.ebay.co.uk/itm/ROVER-200-COU ... CHGNVoxb9A
ROVER-25X (2001 1.4 ROVER 25)
ASTRA TwinTop 1.9CDTi
#8 Post by 961tat » Fri Nov 24, 2017 2:57 pm
Has anyone fitted these FK shockers yet and if so are they any good and what springs did you use ?
:D :D
#9 Post by ROVER-25X » Tue Dec 12, 2017 2:10 am
Not yet pal, won't be touching the Cabby until the garage is built. :D
