Straining wires for cabrio hood
cryptogram
#1 Post by cryptogram » Fri Sep 13, 2019 4:55 pm
I wonder if anyone has a source for the straining wires that run each side of a 216 hood. I'm replacing the hood and one of the wires is bust.
Re: Straining wires for cabrio hood
#2 Post by itcaptainslow » Fri Sep 13, 2019 5:38 pm
I don’t have a knowledge of the specifics of the cabby roof harness, but could you not extend the harness by soldering in a section of repair wire?
As long as the cable is of sufficient rating, the soldering neat and heatshrink (not horrible tape!) used to insulate the repair, I can’t see a problem?
Rover 200 BRM
Rover 214SEI
Kriss707
#3 Post by Kriss707 » Fri Sep 13, 2019 6:41 pm
When I replaced my hood last year I was lucky a previous owner had replaced the original tensioner wires with stainless items. But I have removed hoods where the wires have rusted & snapped.
If you remove the good wire take it to a Chandlers (boat rigging shop) & they will be able to make you some up.
cryptogram
#4 Post by cryptogram » Sat Sep 14, 2019 6:20 pm
Thanks captainslow. This is a possibility.
And thanks Kriss. I definitely this this has legs.
#5 Post by GTiJohn » Sun Sep 15, 2019 4:07 pm
Can you record the lengths - eyelet-to-eyelet - and take photos please, as you won't be the only person who'll need to get these parts replaced? :angel
Tiffa67
#6 Post by Tiffa67 » Sun Sep 15, 2019 6:08 pm
Where abouts are these wires
#7 Post by GTiJohn » Sun Sep 15, 2019 6:44 pm
Where abouts are these wires?
They run above the side windows in between the outer hood and the headlining, on one each side.
They're item 14 in this exploded diagram - https://rimmerbros.com/Item--i-GRID002946
Although they're not mentioned specifically, it might help you understand the construction of the hood if you have a look at this Rover Technical video - https://www.youtube.com/watch?v=7nslNea-mwY too
Tiffa67
#8 Post by Tiffa67 » Mon Sep 16, 2019 9:24 am
