Need help !! Paint code doesn't match my car
Sub-forum for Cabriolet Owners
Peeweemay21
#1 Post by Peeweemay21 » Wed May 11, 2016 9:21 pm
Help please guys !! I own a 1992 white Diamond caddy and I repaired the front drivers side wing. I then got it ready for painting then brought nnd paint code as it's n my car and the paint doesn't match at all,, it's like a grey instead of white ?? Do I need to lacquer it to get the rite match ?? Much appreciated
Re: Need help !! Paint code doesn't match my car
#2 Post by 1234dist » Wed May 11, 2016 9:22 pm
What's the paint code on the plate on the inside of the passenger door?
GMK White Gold 1992-1994
NMN White Diamond 1985-1995
NNG White 1991-1996
NND White Diamond 1990-2000
I think you'll find its NMN
https://youtu.be/8N_tupPBtWQ
#3 Post by crepello » Wed May 11, 2016 10:50 pm
1234dist wrote:I think you'll find its NMN
Oh no :scared . Here we go! (Again.)
#4 Post by Hammond » Wed May 11, 2016 11:08 pm
Your link doesn't work. Try this
https://youtu.be/hqW4qLcRD3w
:*laughing my fat rear end off*
On a more serious note my 1991 GTi White Diamond is NND and its def a different shade than the other white diamond. Mahnahmanah
416Si 'Ocean Blue' (R426 BFC)
414Si 'Ocean Blue' (R478 AHJ)
414SEi 'Bermuda Blue' (V52 VFL)
416GTi Auto 'Diamond White' (J668 GRP)
#5 Post by 1234dist » Thu May 12, 2016 7:51 am
You also have to account for 25 years worth of sun bake, outta the tin probably aint gonna cut it for a large panel.
#6 Post by cabriolet106 » Thu May 12, 2016 6:14 pm
I came across Rover paint code anomalies with my Cabriolet.
My car is painted Platinum Silver or paint code MNX..What I found out was there are 3 shades.
One has more Red in the mix, One has more Grey in the mix and the other is A Mix of both.
Your car could be the same so it may be worth doing a check on the Internet and also some of the auto refinisher suppliers and see what you come up with.
Technical Advisor
#7 Post by E_T_V » Fri May 13, 2016 4:05 pm
Also make sure you've not been supplied with Diamond White (which is a ford colour and very common), rather than White diamond which is a Rover colour.
Peeweemay21
#8 Post by Peeweemay21 » Sat May 14, 2016 11:43 am
Brill guys ! Really appreciate the help.. well it's meant to be nnd paint code but the colour seems to be more like a bluey grey ?!?! Instead of white Diamond and I can accept the fact colour fades over years due to the sun so I thought it may be different but not how it's has turned out :/ so you guys think it may be nmn code ?? I'll check that code instead abd get back to you :) that ks a lot guys and hat soon
#9 Post by 1234dist » Sat May 14, 2016 12:06 pm
Good luck and
:welcome
and while you're at it :kewlpics Please :cool
