220 turbo info
Sub-forum for Coupe Owners
RGNEAVE
220 turbo info
#1 Post by RGNEAVE » Mon May 13, 2013 7:09 pm
im looking for my next project as ive finished and sold my 216 coupe know.
Is the 220 turbo the best coupe to buy for power ?
Is there anything to watch out for on them except the normal.
Im always working on the 1.6 and 1.8 vvcs so fancy a fresh challange on somthing diffrent
also are they hard to find know and whats the price range on them ?
if its NOT a rover forget it or regret it
1999 T Rover 416 Tourer Thitai Blue
1995 N Rover 220 Coupe Turbo Racing Green
1996 P Rover 216 Cabriolet Coupe SE Night Fire Red
Re: 220 turbo info
#2 Post by 1234dist » Mon May 13, 2013 7:55 pm
leak from between the head and block meaning blocked oil line but is common and not that much to worry about.
Power steering pipe leak at the bottom of the engine is common as well.
smoke and or play in the turbo blades.
Other than that bullet proof
RGNEAVE
Re: 220 turbo info
#3 Post by RGNEAVE » Mon May 13, 2013 8:15 pm
great stuff thanks
ill start serching and hoping ill find one in the next coupe of weeks so watch this space ive put my feelers out already
Im ideal one would be white with red half leather on an N plate
Re: 220 turbo info
#4 Post by 1234dist » Mon May 13, 2013 8:29 pm
biggest advice I can give is be patient.
I do know of a t-reg coupe turbo in brg going for £600 from an enthusiast if you want me to pass details on?
RGNEAVE
Re: 220 turbo info
#5 Post by RGNEAVE » Mon May 13, 2013 9:23 pm
would that be a conversion as i thort the t 16 was discontinued in 95 - 96 somthime and replaced with the vvc
yer you can do would like an origonal factory fitted turbo but worth a good look
thanks
Re: 220 turbo info
#6 Post by 1234dist » Tue May 14, 2013 7:33 am
As far as I am aware its an original.
tompinney
Re: 220 turbo info
#7 Post by tompinney » Tue May 14, 2013 9:36 am
Tom
Above all, it's a Rover!
-1993 420GSi Sport Turbo (The 'Rumm Chuff' :))
RGNEAVE
Re: 220 turbo info
#8 Post by RGNEAVE » Fri May 17, 2013 8:01 am
24 hours to go until i collect my 220 coupe turbo
ill post pics when shes home
RGNEAVE
Re: 220 turbo info
#9 Post by RGNEAVE » Sat May 18, 2013 6:06 pm
Her she is
1996 N Reg
62000 Miles
Some service history
Please note this car has been stood for the last 10 years A good clean and a new drivers door and shes as good as can be.
Alread sourced the door collecting tomorrow.
There is a small oil leak from the front rocker gasket but everything else is fine on it starts first time and runs well Very quick
The engine is a bit rusty buy she has been stood for so long
Need to get
Rover Radio
New tyers
Window Wipers
1 x rear break pipe
Has anybody got a T16 Engine manual in pdf or can tell me of anyware that sells a book as ive only ever worked on 1.6 Ks
Can anyone guess how much she cost me :D
Re: 220 turbo info
#10 Post by 1234dist » Sat May 18, 2013 6:19 pm
don't worry about the oil leak that's normal.
Full service and a run on the motorway up to 70 :wink3 in fourth should get rid of a few cobwebs.
A lot of hard braking will clean the brakes off until you replace them (if your going too).
RGNEAVE
Re: 220 turbo info
#11 Post by RGNEAVE » Sat May 18, 2013 6:22 pm
great thankd for that.
Is the T16 any harder to work on ie changing the belts ect ect
Re: 220 turbo info
#12 Post by GTiJohn » Sat May 18, 2013 6:31 pm
With a smile like that it must be well south of £500.
Looks a great find :clapping
RGNEAVE
Re: 220 turbo info
#13 Post by RGNEAVE » Sat May 18, 2013 6:33 pm
Yer a lot south put it this way if i sold a couple of bits it would cover her
£100 on the head but had to copllect today or it was £250
If anyone has any of the following i would be happey to purchase
Spark plug cover
rear boot carpet
pm me if anyone has anything
4V8s
Re: 220 turbo info
#14 Post by 4V8s » Sat May 18, 2013 11:49 pm
what, £100? Bargain! If I had an opportunity like that I would have to indulge too (even though I already have 8 cars and it would almost certainly cause divorce! :-)
Rover 214Si 16v 1994
Rover Mini Cooper 1997
1977 Pontiac Firebird 403 V8
RGNEAVE
Re: 220 turbo info
#15 Post by RGNEAVE » Sun May 19, 2013 9:36 am
i know that feeling well.
Told my partner i was at work and then apeared with it on the drive *laughs* got told off but shes ok with it
she askeif it was for her but just lerning to drive the insurance would kill me *laughs*
Ive had an mot inspection on it and it just needs a replacment break pipe and tyers to pass a test
I get the chance of a few like this most are just scrap but few good ones appear.
The last one im after is a standard 5 door salloon model my be in 6 - 12 months
