Track R8 214 Sprint
redandwhitE
Re: Track R8 214 Sprint
#61 Post by redandwhitE » Sat Mar 31, 2018 10:09 pm
Understand.....shame that our better halves never do!
1995 416 SLi (Ostensibly BRG) - on the road
2000 Citroen Xantia Estate (silver) - on the road
2006 Ford Transit (white, what else) - on the road
1972 Mercedes 350 SL (red) - not on the road
1998 Audi Cabriolet (maroon) - not on the road
#62 Post by JOHNDQ » Sat Mar 31, 2018 10:20 pm
True all tho to be fair she isn't to bad about it this is the 3rd car now so I'm under orders it has to be the last :wink3
redandwhitE
#63 Post by redandwhitE » Sat Mar 31, 2018 10:25 pm
....and there's always motorbikes or steam engines or vans or buses or.......
#64 Post by JOHNDQ » Sat Mar 31, 2018 10:33 pm
I like your thinking but after Devo divorce can't imagine be much left over for that :tt2
#65 Post by JOHNDQ » Sun Apr 01, 2018 9:06 pm
Well at last the engine is finally in was starting to think this day would never come....
ImageIMG_20180401_165107~2 by John Quincey, on Flickr
ImageIMG_20180401_192711~2 by John Quincey, on Flickr
ImageIMG_20180401_192730~2 by John Quincey, on Flickr
ImageIMG_20180401_192743~2 by John Quincey, on Flickr
#66 Post by JOHNDQ » Sun Apr 08, 2018 10:08 pm
Well unfortunately weather didnt play ball this weekend but got a fair bit done on Saturday so fingers crossed should be at POL. Anyway while the weather was bad today i got the loom made that will link the engine to the engine bay fuse box and into the car. Just need to test fit it to make sure everything is the right length and i havent missed anything before covering it with flame and fluid resistant heat shrink....
Image2018-04-08_09-57-23 by John Quincey, on Flickr
#67 Post by JOHNDQ » Sun Apr 22, 2018 10:24 pm
Just a quick one to keep thread going. Unfortunately due to work and kids party's at weekends still running behind but not far off now just the final bits of wiring, coolant pluming and exhaust to sort and should be there i think.
Another few of wiring, hoping to have it finished this week still waiting on the Deutsch crimpers to come so can get the multi plugs on....
ImageIMG_20180420_001624~2 by John Quincey, on Flickr
ImageIMG_20180420_194500~2 by John Quincey, on Flickr
Few of the car finally got the bumper top coated and the panels back on....
ImageIMG_20180422_202929~2 by John Quincey, on Flickr
ImageIMG_20180422_202945~2 by John Quincey, on Flickr
ImageIMG_20180422_203537~3 by John Quincey, on FlickrImageIMG_20180422_203549~2 by John Quincey, on Flickr
Ive also booked the car in my local car show "the haynes 100" (idea is to have a car from each year covering 100 years) in June to cover 1993
#68 Post by JOHNDQ » Sun May 06, 2018 10:11 pm
Well started what i thought was going to be a easy job today. Thought i would get the Coupe bonnet flatted and grill holes sorted ready to get painted next week so flatted the top coat down....
Image2018-05-06_09-39-38 by John Quincey, on Flickr
But once i took off the top coats found a few touch up and poor repairs.....
Image2018-05-06_09-39-55 by John Quincey, on Flickr
So had to take those spots back to bear metal and add a skim of filler....
Image2018-05-06_09-41-22 by John Quincey, on Flickr
Image2018-05-06_09-41-46 by John Quincey, on Flickr
Then flatted again followed by a coat of high build primer...
Image2018-05-06_09-42-06 by John Quincey, on Flickr
Then the joys of a wet flat of first 1200 followed by another wet flat of 2000 to get it nice and smooth.....
Image2018-05-06_09-42-29 by John Quincey, on Flickr
So after best part of the day its really for the body shop but bearing in mind its only getting used on track and will most likely be stoned chipped first time probably been a waste of time.
#69 Post by JOHNDQ » Thu May 10, 2018 9:22 pm
Bit more done today just getting wiring finished hoping to get the ignition on tomorrow at last....
First off adding the Solder sleeve's onto the shielded cables to allow any noise to travel to earth for the Lambda and crank sensor signals. I dont run a cam sensor on mine engine so only 2 needed....
ImageIMG_20180510_205342 by John Quincey, on Flickr
Few of the plugs and terminals using gold plated terminals for all sensor signals and standard for power and grounds....
ImageIMG_20180509_211736 by John Quincey, on Flickr
Adding in the splices for common power and grounds and covered with Motorsport Raychem spec ES2 end caps.....
ImageIMG_20180509_211716 by John Quincey, on Flickr
For the join between the engine bay and inside ive used Motorsport spec Deutsch DT Series plugs so should the engine need to come out i just need to disconnect the plugs and all wiring from the engine and engine bay fuse box etc will come all together nice and easy with the engine with all sensor signals on 1 plug, powers and ground on the other 24 pins in total. The plugs are mated male to female, female to mate so i cant mis-match them and blow the ecu.....
ImageIMG_20180510_183717~2 by John Quincey, on Flickr
And finally i stripped, cleaned, rebuilt and sprayed the Alternator as everything else has been done....
ImageIMG_20180509_211924 by John Quincey, on Flickr
Aaronrover214cab1993
#70 Post by Aaronrover214cab1993 » Fri May 11, 2018 10:08 pm
Looking great mate nice chat the other night too the time flew *laughs*
#71 Post by JOHNDQ » Fri May 11, 2018 10:29 pm
Cheers mate hopefully I'll get those bits on tomoz hoping to finally start it this weekend :wink3
#72 Post by JOHNDQ » Sat May 12, 2018 8:58 pm
Well good news SHE RUNS :tt2 And all the mating of my loom to the factory fuse box etc is good so got all all the warning lights on dash and instruments. Only had it running for few secs as I forgot to order a new radiator some how and still need to get exhaust sorted :headbanging
Vulgalour
#73 Post by Vulgalour » Sat May 19, 2018 1:00 am
Lots of really good progress in here, that engine bay is looking nice and clean and tidy.
Current Fleet:
1994 Rover 414 SLi
#74 Post by JOHNDQ » Sat May 19, 2018 6:17 am
Thanks mate :cool
#75 Post by JOHNDQ » Mon May 28, 2018 12:22 am
Little update, ive changed the Lotus Cam Cover to a Rover unit and was a bit bored today so made a little YouTube video. I also wired in the ABS warning light in as a shift light which comes on at 6500 rpm on the "road map" and 7300 rpm on "track map"....
https://www.youtube.com/watch?v=XUwU8xsgfbk
