Head lining
Use this board for any non-technical 200 or 400 related topic including motorsport, trivia, insurance matters etc.
george@gmpy.co.uk
Head lining
#1 Post by george@gmpy.co.uk » Tue Dec 24, 2019 3:14 pm
Hi can eny one tell me the probable cost of fixing the head liner which is sagging over the passenger visor ,the liner is pristine just apache two foot by one ,not bad but annoying
George
Re: Head lineing
#2 Post by 1234dist » Tue Dec 24, 2019 6:24 pm
About 3hrs of your life over 2 days and a tin of fast contact spray glue.
Re: Head lineing
#3 Post by Johnny 216GSi » Tue Dec 24, 2019 7:18 pm
George
You won't be able to fix your existing headliner with glue. The reason it's sagging is that the scrim foam on the back has completely perished (turned to orange dust). The brushed nylon itself is no thicker than a pair of sheer tights (I don't wear them myself... :laughing2 ). Any glue you put on the other side will just soak/push through in seconds. You could try a very high performance double sided tape like 3M's product "9088-200" (search for it on Ebay).
Other than that, you'll have to buy new light-grey headlining material which should be brushed nylon on one side and it will have a 3mm scrim foam bonded to the other side. Price can range from about £12 to £25 per metre, and you'll need 2 metres off a wide roll. Glue is about £10-£15 per can. Buy the high-temperature stuff rated 120 to 150 degrees C, as the roof of a car can get very hot in direct sunlight. You can probably do it in 2 cans - you need to spray in one direction on the headlining foam, and the opposite direction on the headlining shell. Wait for the glue to go tacky (it's pretty tacky even right after you've sprayed it), bring the two together and press and smooth all over, then trim.
Getting the shell out and back in does take a few hours - all the roof furniture has to come off (sun visors, grab handles), the rear strip, the rear quarter light internal trim, the B-post trim and A/B/C upper trim, the front seat belt top anchors (to get the A/B/C upper trim off), the inner rubber door seals, sunroof trim, interior light, etc. If you've a hatchback, the shell ejects from the boot easily with the rear seat down and parcel shelf removed. If it's a 4-door then ideally the back seat needs to be taken out, although a "botch" is to force the shell out through one of the rear passenger doors. It doesn't actually fit through the rear door without bending and scraping it everywhere, but people seem to want the quickest/nastiest solution so that's what most people do.
george@gmpy.co.uk
Re: Head lining
#4 Post by george@gmpy.co.uk » Fri Dec 27, 2019 8:41 pm
Thanks for such a detailed reply,,thinkit beyond my ability I'll talk to a a car interior company,sounds a expensive experience ..
redandwhitE
Re: Head lining
#5 Post by redandwhitE » Fri Feb 14, 2020 2:38 am
Johnny 216 Gsi: From your attention to detail and consideration to finish and appearance, it's clear you'd be a stockings man and not tights!
1995 416 SLi (Ostensibly BRG) - on the road
1998 VW Polo 1.9D CL (purple) - on the road
1993 416 GSi (BRG) - not on the road
1972 Mercedes 350 SL (red) - not on the road
1998 Audi Cabriolet (maroon) - not on the road
Re: Head lineing
#6 Post by 961tat » Fri Feb 14, 2020 11:47 am
George
Happy day at the NEC :tt2
Re: Head lining
#7 Post by 1234dist » Fri Feb 14, 2020 12:36 pm
I have a spare good condition 4dr headlining if anyone needs it?
george@gmpy.co.uk
Re: Head lining
#8 Post by george@gmpy.co.uk » Sat Mar 28, 2020 8:17 pm
Hi Guys
OK grasped the nettle,picked her up last week, absolutely lovely job, a eye watering £400 but a really beautiful job,recommend MJ uphosters Bedford,
When I first went to see him he was doing a Austin Ruby inside and out wonderful job l was instantly sold.
Vinny1979
Re: Head lining
#9 Post by Vinny1979 » Sun Mar 29, 2020 11:55 am
:scared
carfixmobile
Re: Head lining
#10 Post by carfixmobile » Sun Mar 29, 2020 3:07 pm
I am having a go myself. Taking the headlining out was a relatively simple job (5 door hatch makes it easier).
As been mentioned above the foam under the headlining has turned to an orange "dust". Scraping it off the headlining shell is messy.
I have made contact with a company called "Woolies". They have a catalogue as well as a website. They do a fantastic array of parts for trim and upholstery for cars. This includes a range of foam backed nylon headlining material and the high heat resistant spray adhesive.
I have not ordered anything yet but will report back when I do.
Re: Head lining
#11 Post by crepello » Sun Mar 29, 2020 5:30 pm
Woolies are the go-to source for this sort of thing. I did mine with material from them.
You can order with confidence!
