Je suis Crapaud.
Vulgalour
Je suis Crapaud.
#1 Post by Vulgalour » Sat Mar 18, 2017 2:52 am
I saved this little green Renault back in 2014.
The kindness of a more local enthusiast saw it collected from the field it had been living in for a year or two, before which it had been in a barn since the early 90s. I didn't even know what a Renault 6 was, but at £80 and the threat of the crusher looming I took a chance on it. Another enthusiast collected it with his Xantia estate for me.
I then collected it in my Xantia estate. What are the chances of that?
Over the next couple of years I worked on getting the car sorted out. It might be fundamentally a Renault 4 underneath the bodywork but my goodness has it proven to be a challenge to figure out which were the correct parts. I could never have done it without various fora and the internet at large, with parts coming in from all over Europe and even a few in the UK. You try finding right hand drive headlights for a car of which there's maybe a dozen left in the UK! Managed it though, and this year I finally got it enough together and with many, many new parts so that I could hopefully get it running and MoT'd.
Sadly, after quite a battle with it, the little green car just doesn't want to know. I've reached the end of the road with this one and it's time for someone else to have a tinker. It's my very first full engine rebuild and while it's a simple engine with its ancestry being the Renault 4CV, it's incredibly difficult to work on in situ. After a long time of chasing problems and suggestions ranging from sticking valves, to bad ignition timing, to incorrectly aligned camshafts and more, I've decided to call it quits at a point I'm comfortable walking away from it.
This little car has fought me most of the way and while I find its quirky Frenchness endearing, I'm hoping he'll find a new owner able to get over these last few hurdles. I think I'll be sad to see this one go, as well as relieved. I've given it the best chance and if the right owner comes along it will undoubtedly see the road again.
I'm the third owner, the car has done 132,000 miles, I've had it three years and I've never been able to drive it. The closest I got was being towed around the yard when I learned the driving position was rather more offset than I'm comfortable with. It's been a fun project. Maybe next year I'll get something even weirder.
The rabbit fabric headlining is a particular high point, I enjoyed making that and I shall probably miss that the most. The car earned the name Crapaud (French for toad) for it is small, lumpy and green.
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
Re: Je suis Crapaud.
#2 Post by GTiJohn » Sat Mar 18, 2017 7:24 am
What a fascinating story. Pity you can't take it the last few metres to completion but life is sometimes about knowing when to let go.
The imminent Resto show would seem like a good place to look for a new owner. I'm sure there will be one or more Renault/French enthusiasts owners clubs there. Why do you put together a flier to advertise it and either take it round yourself if you're attending, or one of us will.
That's assuming no Maxi lovers amongst us has a French fancy... :wink3
#3 Post by 1234dist » Sat Mar 18, 2017 7:38 am
Such a shame so close to the finish line.
But it happens, regularly unfortunately.
Is there no one in the french carp owners club that could maybe pop down for a fix it day.
Brew and bacon is usually required but fresh eyes always makes a difference.
Vulgalour
#4 Post by Vulgalour » Sat Mar 18, 2017 8:33 pm
Oh the problem is sure to be a simple one. These things normally are. At this point it needs a more experienced eye cast over it to get to the bottom of the problem, whatever it might be. Engines are the one thing I don't enjoy working on, that and electrics. Everything else I'm pretty comfortable with.
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
#5 Post by 220 GSi turbo » Sat Mar 18, 2017 11:55 pm
My mate's first car was a Renault 6 (bright red) but terminal rust around the rear end meant that it never survived to see its 10th birthday :o
He replaced it with a purple Marina 1.8 TC Coupe :cool and that survives to this day (although not in his ownership)
We had great fun with his R6, although he couldn't keep up with my Austin 1300GT, especially on the twisty bits :laughing2
Yours has done well to last as long as it has! I don't know if this will help with your non-start problem, but I seem to remember that the engine runs 'backwards', so great care is needed when connecting HT leads to the distributor cap.
1995 220GSi Turbo: owned for 17 years
Vulgalour
#6 Post by Vulgalour » Sun Mar 19, 2017 1:37 pm
I've been through the plug lead order on this one and got other people to do the same, tried different combinations, ignored, the manual, followed the manual... suffice to say the way around they are now is the only way around they go. It's odd though because it does behave a bit like two leads are the wrong way around, they're just not.
It's one of those where every item has been gone through and nothing can be found amiss. That probably means the new owner will go through it all to check what he's got, stick a key in, and it'll fire straight up without them actually having to change anything. For me, I'm back to browsing eBay and looking at terrible things like Triumph TR7s and Mayflowers and abandoned Maxis. There's so many cars I want to have a go at, it's hard to know what to go for!
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
Raider
Enthusiast
#7 Post by Raider » Sun Mar 19, 2017 2:42 pm
I have 2 TR7S and love them :o
1969 Triumph 2000
1977 Triumph TR7 16V rally car
1982 Triumph TR7 dhc
1992 Mini Mayfair
1992 Rover 214i
1995 Rover 214 SEi
http://raidertr7.blogspot.co.uk/
Numptey
Golden Oldie
Car Ownership: Other Rover
#8 Post by Numptey » Mon Mar 20, 2017 9:47 am
Must be worth a few quid, why not ebay it?
Your Xantia estate looks lovely, had a BX myself years ago the suspension was awesome
Vulgalour
#9 Post by Vulgalour » Tue Mar 21, 2017 12:22 pm
Because eBay is full of chancers and morons and I'd rather avoid it at all costs. Gumtree is worse. The Xantia was a superb old bus, unfortunately the seating position in it caused me chronic back pain otherwise I'd likely still have it.
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
#10 Post by Paul_1978_yorks » Wed Mar 22, 2017 7:37 am
Vulgalour wrote:I've been through the plug lead order on this one and got other people to do the same, tried different combinations, ignored, the manual, followed the manual... suffice to say the way around they are now is the only way around they go. It's odd though because it does behave a bit like two leads are the wrong way around, they're just not.
There's a 1750 Maxi on eBay at the minute, barn find (really!), been off the road since 1997.
Vulgalour
#11 Post by Vulgalour » Wed Mar 22, 2017 5:52 pm
Well... since the Renault sold this afternoon in a very painless transaction and I now have money in my pocket...
I'm going to resist the temptation of orange Maxis and instead buy boring things like catalytic converters and tyres and petrol for my British cars. Princess MoT on the 3rd of April and hopefully after that Pride of Longbridge and some other events. Just have to see how far my pennies will stretch.
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
#12 Post by GTiJohn » Wed Mar 22, 2017 7:07 pm
Sometimes you just have to say goodbye :sad
Vulgalour
#13 Post by Vulgalour » Wed Mar 22, 2017 10:27 pm
Given that I pretty much broke even on what money I put into this car and gave it the best chance at survival, I'm content with the outcome. New owner was considering repainting it in the original metallic green, I think it was called Fern Green, which really suits the Renault and goes well with the tan interior. Difficult to find examples of it online, I think it's the same as this Renault 18 and possibly the same colour on this 4.
But not this 6 which seems to be a paler, less yellowy green and more common on late model Spanish cars.
Anyway, it's not my worry any more. Hopefully the new owner will stay in touch and I can help with any items he gets stuck with and hopefully if he gets it running he can tell me what exactly was amiss on it, I'd actually love to know what was stopping it running properly, I bet it's something daft.
Current Fleet:
1972 Austin 1100
1994 Rover 414 SLi
