SGS 3 TONNE HEAVY DUTY TROLLEY JACK
Found a reccomended supplier of products or services? Think others would benefit? Then leave feedback in here and let us know about it.
#1 Post by Mr Teddy Bear » Tue Jul 04, 2017 4:10 pm
DO YOU NEED TO GET UNDER YOUR CAR TO DO STUFF?
Superior quality, heavy duty, big bad boy trolley jack. :groupwave
A must have piece of kit, unless you already own a two post lift! :tt2
I believe that SGS manufacture these and sell/distribute via Ebay. Max lift height of over half a metre, that's approx' 20 inches for us oldies. Large lift table 4.5" dia', with optional fitted rubber pad. Large rubber covered [4.5 ft] two part lift handle; single location pump to raise/twist to lower operation.
Wouldn't look out-of-place in a professional workshop or retailing at twice the price!
Bought on Friday and delivered by Tuesday lunchtime.
Re: SGS 3 TONNE HEAVY DUTY TROLLEY JACK
#2 Post by Johnny 216GSi » Tue Jul 04, 2017 11:25 pm
Mr Teddy Bear wrote:DO YOU NEED TO GET UNDER YOUR CAR TO DO STUFF?
They do look the absolute business. Link for anyone interested:
http://www.ebay.co.uk/itm/3-Ton-Heavy-D ... 1028680739
They've shifted over 2,000 of these things.
Now if I just had access to some flat-and-level ground, I could buy one and as you say - get under the car instead of paying for someone else's spanner time, not that I rate my ability to be able to do any of the necessary :laughing2
#3 Post by Mr Teddy Bear » Thu Jul 06, 2017 12:43 pm
Just to add that the Ebay photograph's don't convey the size and construction. The two longitudinal steel plates that form the chassis, are 1/4" thick!
#4 Post by 1234dist » Thu Jul 06, 2017 1:21 pm
how bout some proper pics in relation to say a tyre ect.
#5 Post by crepello » Thu Jul 06, 2017 2:21 pm
And "how low can you go" as the saying goes. Will it fit under a suspension arm with wheel grounded, for instance.
#6 Post by Mr Teddy Bear » Sat Jul 08, 2017 4:26 pm
If you look at the spec I expect that it would, although I try to only put a jack under the recognised jacking points.
Photo's aren't my strong point. :blushing
