Rover 216 GTI (new engine)
bhlegit
Re: Rover 216 GTI (new engine)
#16 Post by bhlegit » Wed Dec 27, 2017 6:15 pm
noprobs found this:
D16A8
Found in:
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992-1995 Rover 216/416 GTi(UK/Europe)
1993-1997 Rover 216 SportCoupe (Europe)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Compression : 9.5:1
Power : 125 hp (93.2 kW, 127 ps) @ 6800 rpm
Torque : 108 ft·lbf (14.9 kg/m, 146 Nm) @ 5900 rpm
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 MPFI
ECU Code : PP5
Gearbox : L3
D16A9
(Same as D16A8 but without a catalytic converter)
Found in:
1988-1991 Concerto (UK/Europe)
1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
1989-1992 Rover 216/416 GTi (UK/Europe)
1992-1995 Civic Si (Japanese and Peruvian version)
Displacement : 1,595 cc (97 cu in)
Compression : 9.5:1 (p29 pistons)
Power : 137 hp (96.9 kW, 132 ps) @ 6.800 rpm
Valvetrain : DOHC 16 valve (4 valves per cylinder)
Redline: 7500 rpm
Limit: 7800 rpm
Fuel Control : 88-91 OBD-0 MPFI (92-95 OBD-1)
ECU Code: PM7
GearBox : <non LSD> (88-91 L3) (LSD 92- 95 S20)
so defo want to stay with the original d16a9 engine
#17 Post by Paul_1978_yorks » Wed Dec 27, 2017 6:49 pm
That sounds about right. My old 416 (SOHC) was pre-cat but my later 216 did have a cat.
bhlegit
#18 Post by bhlegit » Wed Dec 27, 2017 7:37 pm
So still looking lads! pls share if you see anything. Cheers
#19 Post by Mr Teddy Bear » Wed Dec 27, 2017 9:55 pm
That cabby is a M [95] It's the Honda DOHC with a Catalyst exhaust fitted. The earlier non cat engines have different valve timing and thus different cam shafts fitted according to my Rover [Honda] engine overhaul manual. That as far as I'm aware is the major [only?] differences between the engines.
Rover 216 Sli SRS Charcoal Colour Coded bumpers 1996
Rover 216 GTi Flame Red 1992
Rover 414Si British Racing Green 1995
Rover 216GTi TC Ocean Blue 1993
bhlegit
#20 Post by bhlegit » Thu Dec 28, 2017 6:38 pm
yep of the 4 cabbys i managed to find all are d16a8 engines :( still waiting to hear about the gti's in the scrapyard
#21 Post by JOHNDQ » Thu Dec 28, 2017 7:32 pm
What scrappy you found a GTI in? Don't worry I'm not after a engine
bhlegit
#22 Post by bhlegit » Thu Dec 28, 2017 7:44 pm
@JOHNDQ one on ebay called becrow dismantlers who had a cabby up and i messaged him he said he also had 2 216 gtis (waiting to hear back), also theres another one but its offline i'd have to find the name again as have been calling around many
bhlegit
#23 Post by bhlegit » Thu Dec 28, 2017 7:44 pm
im also after drivers side rear quarter panel so dont cop that!!1 :)
bhlegit
#24 Post by bhlegit » Thu Dec 28, 2017 7:45 pm
and headlights and original radio. thats why ideally im looking for whole donor car with d16a9 then i can take other bits off it i might need
#25 Post by JOHNDQ » Thu Dec 28, 2017 8:49 pm
Thanks, no not after any of those bits did have a radio but unfortunately sold that few weeks back
#26 Post by Paul_1978_yorks » Thu Dec 28, 2017 11:29 pm
Be interested to hear more about the GTis. They’re rare these days, and really shouldn’t be in scrapyards unless they’re shot to pieces.
#27 Post by JOHNDQ » Thu Dec 28, 2017 11:55 pm
I dont think they would be unless there rotten tbh
#28 Post by Paul_1978_yorks » Fri Dec 29, 2017 12:40 am
Not necessarily. Seen plenty of perfectly serviceable R8’s in scrapyards because the owners either can’t be bothered selling them or they think they are worthless.
bhlegit
#29 Post by bhlegit » Fri Dec 29, 2017 7:39 pm
still no luck :( i think i have seen every cabby for sale in uk now *laughs*
richard moss
#30 Post by richard moss » Sat Dec 30, 2017 12:14 am
If I remember correctly, the block from the single cam and twin cam D series engines is the same - so the head from the twin cam can be swapped over
Out in the desert with 2 old Jeeps and a Landrover D2.
Back home: wife's 1993 216 DOHC Cabriolet and my 1969 MGC GT
