Search found 393 matches
by StubbornPatriot
Thu Aug 13, 2026 7:01 pm
Topic: New Streetwise
Re: New Streetwise
Hi Steve. Welcome to the club. You're in the right place for help and advice. Looks like you've got the basis for a good car there. As you say, most of the issues are minor niggles. The tailgate loom is a common issue on the older 'R8' models, I hadn't realised it was affecting the R3s, like yours. ...
by StubbornPatriot
Wed Jul 01, 2026 10:17 pm
Topic: Bumper Rubber strip clean up
Re: Bumper Rubber strip clean up
According to an internet search, you can do it using a Pencil Eraser. There's a YouTube video showing it seems to work, some positive comments agreeing on its efficacy but one-or-two saying it didn't work for them. Haven't tried it myself but I will.
https://www.youtube.com/watch?v=QUyjrubOCOA
by StubbornPatriot
Tue Jun 30, 2026 9:11 pm
Topic: Rover 416 auto 1997
Re: Rover 416 auto 1997
Is this the one? https://www.ebay.co.uk/itm/227332656313?_skw=rover+416+ABS+Sensor+-Land+-Range+-battery+-aerosol+-raptor+-75&itmmeta=01KWD37A2Q8R8DT5WX3B9WYKDE&hash=item34ee150cb9:g:rqoAAeSwjmBo8CWq&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xBridaMcDNz0m7U4jJR5qnp0w6NwHg3u5JpDfhRRTyMakc...
by StubbornPatriot
Mon Mar 30, 2026 8:13 am
Topic: Headliner - Replacing scrimfoam but retaining material
Re: Headliner - Replacing scrimfoam but retaining material
Thanks Iain. Would that be for them to do the job or for them to supply the material?
by StubbornPatriot
Mon Mar 30, 2026 7:27 am
Has anyone replaced the scrim foam in their headlining but retained the original grey material? If so, what adhesive was used to stick the original grey material to the new scrim foam? Looking at samples of various replacement headlining material, none of them seem to have the same texture as the or...
by StubbornPatriot
Mon Feb 16, 2026 4:02 pm
Topic: Heater Controls 94 216
Re: Heater Controls 94 216
You don't have to take the dash to bits - the knobs just pull off (carefully). It is probable that the plastic sleeves have fractured and are no longer holding the metal insert tight, so they rotate without actually gripping the inner shaft. In all probability you'll have to try and find some good, ...
by StubbornPatriot
Thu Dec 25, 2025 12:28 am
Topic: 1994 416SLi tourer Distributer
Re: 1994 416SLi tourer Distributer
Would this be the one:- https://www.ebay.co.uk/itm/142481374036?_skw=rover+distributor+-v8+-land+-range&itmmeta=01KD9E5FFYKF1Z9D13NXG1W6N6&hash=item212c8d3b54%3Ag%3AleYAAeSw85ZodMVN&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1fJnT5rwcdIBBQzsGeqA3L8fRpTGvXwAwYugspN67bo%2B0wAE0jUlmqa%2FVUa4...
by StubbornPatriot
Tue Dec 16, 2025 10:25 pm
Forum: The Lounge
Topic: Humour
Re: Humour
Good observation Dorch.
So, as haiku-
I heard a new joke
about a broken pencil
but it is pointless
by StubbornPatriot
Sat Dec 06, 2025 11:54 pm
Topic: 420 R8 drive shaft
Re: 420 R8 drive shaft
Did you use a new snap ring? If you reused the old one it could well have broken, or dislocated, when you refitted the driveshaft. Many years ago I had this problem, on a 216 Honda engine, when a mechanic did a repair for me. After the repair, first time on full lock, the driveshaft dropped out. Whe...
by StubbornPatriot
Sat Nov 29, 2025 10:32 pm
Topic: R8 416 Front Subframe
Re: R8 416 Front Subframe
I suggest you send a PM to 961tat on here. Worst case is you get a K series front subframe and have the Honda engine mount transplanted from your old one. 961tat can probably still do this. I've got a couple of NOS K series front-subframes if you can't get one from elsewhere.
