Search found 131 matches
by Roverlike
Sun Jul 19, 2026 2:57 pm
Topic: Rover 200 R3 Central Console Connectors
Re: Rover 200 R3 Central Console Connectors
Glad to be of help :)
by Roverlike
Mon Jul 13, 2026 5:56 pm
1), 2), 3) Two red connectors are within yellow sleeves. Everything within yellow sleeves belongs to airbags. These 2 connectors belong to passanger airbag. Do you have it? If not they are left alone. 4) This is the connector which goes into radio which does not have display integrated within, but u...
by Roverlike
Tue Jun 16, 2026 4:07 am
Topic: Philips R960 remote steering wheel controls for R8
Re: Philips R960 remote steering wheel controls for R8
If you are using 200 ohm range it is too small. You are expecting values of 390 ohm, 470 ohm and 820 ohm. You need to use greater scale like 2k ohm.
More recent version of steering wheel switches use 82 ohm, 120 ohm and 270 ohm values.
by Roverlike
Sun Jun 14, 2026 7:28 pm
Resistance of the switches can be measured by ohmmeter, not voltmeter.
by Roverlike
Sat Jun 06, 2026 9:16 am
In case of Philips R760 and R770 sideway connector is used solely for clock-display since they do not have built in display. Steering wheel controls (2 pins) are part of ISO A block in which you have power connectors.
As far as I know Philips R860 share the same principle as R770.
by Roverlike
Fri Feb 20, 2026 6:19 am
Topic: Streetwise Wheels
Re: Streetwise Wheels
In mentioned thread you have PCD and width of all alloys. Rover Streetwise PCD 4 x 100, width depending on alloy or steel wheel, ET45 Rover 200 series of R3 body shape had steel wheel 5J, 14 inch, while Rover 25 had steel wheel 5.5J, 14 inch. Rover 600 PCD 4 x 114.3, width depending on alloy or stee...
by Roverlike
Thu Feb 19, 2026 5:44 am
Maybe this thread I made long time go might help you: https://www.mg-rover.org/threads/mg-rov ... st-8476489
Streetwise alloys are under name Blade.
by Roverlike
Fri Feb 06, 2026 5:42 am
Topic: 1994 216i Cabrio with Honda DA16A8 Engine
Re: 1994 216i Cabrio with Honda DA16A8 Engine
If you have Lucas 5AS alarm system that 3-pin green plug should be diagnostic connector for Lucas 5AS alarm system.
by Roverlike
Tue Jan 06, 2026 8:12 am
Topic: reset central locking Rover 25
Re: reset central locking Rover 25
Since you have Lucas 5AS system in your car, every time you replace/disconnect car battery or battery in your fob you need to re-sync it with the car. Otherwise you will not be able to start your car as you can see. Fob is not there just for central locking but for alarm as well. So you need to pres...
