Search found 289 matches
- Mon Aug 08, 2016 9:45 pm
- Forum: The Gallery
- Topic: G-reg Rover 416 GSi
Re: G-reg Rover 416 GSi
That looks really good. Those wheels look just right on that model and anything else would be an undesirable modification on such an original-looking car.
- Fri Jun 24, 2016 8:12 pm
Or the car was registered in Peterborough and then resold at the Ware dealership.
- Fri Jun 24, 2016 12:23 am
The sunroof is standard, the a/c would have been an option.
I see it doesn't have the top spec radio cassette as fitted to the GTi and other top of the range models such as MG Montegos and Rover 800s.
- Sun May 08, 2016 10:14 pm
- Topic: 416 GTi broken down - help/advice sought!
Re: 416 GTi broken down - help/advice sought!
Yes, it's good. This is the second time the car has had a reprieve because I bought it as a non-runner as the previous owner bailed when the alternator failed - which was the first fix I did on the car. But to be honest, if I'd had to spend £450+ for a new distributor, I may have wobbled a bit! Now ...
- Fri May 06, 2016 10:52 pm
Yes there a little sachet of white stuff. I applied it as suggested. I have three sets of wheels: 1. The cross-spokes on the car that are not kerbed, hold air and look original. They do have a lot of caked on brake dust. 2. Brand new set of cross-spokes still in the original packaging. 3. Newly acqu...
- Fri May 06, 2016 10:29 pm
The igniter arrived today and I fitted it and... Drum roll.. The car started! I was a little surprised because I was worried that I'd end up chasing parts round the engine changing this that or the other. I used the old distributor cap and rotor arm as they seemed to be okay. The old igniter looked ...
- Wed May 04, 2016 9:48 pm
First setback today. The distributor cap arrived but it was quite different from the one I have removed. It is much shallower and the holes for the bolts are in a different place. I'll have to send it back (it was advertised as fitting the car). Anyway the main part, the igniter has not arrived yet....
- Wed May 04, 2016 11:17 am
A new igniter is on its way to me. I'll be fitting that and a new distributor cap when it arrives. Cost so far £36.
If that works, happy days. If not, I'll check out the relay you mention. However the normal clicks and whirs are all still there when I turn on the ignition.
- Tue May 03, 2016 8:07 am
Thanks Johnny.
Yes, the engine refused to restart even after I had towed it home and it had cooled down. The Check Engine light comes on (and goes out) as normal when the ignition is switched on.
- Mon May 02, 2016 10:26 pm
One flash when I first turned the ignition on. I pulled out fuse 4 (which wasn't hazards) and a few others but I couldn't get any more than one flash of the LED.Johnny 216GSi wrote:Did you see if the ECU LED is flashing?
Anyway I am going to buy one of those igniters and see how I get on.
