Search found 82 matches
by Bean66
Sun Feb 22, 2026 11:26 pm
Topic: Streetwise Wheels
Re: Streetwise Wheels
Cheers for that, just the info i was after.
I know its a bit of a daft idea but if i can get some wheels cheapo migh be doable.
Thanks Bean
by Bean66
Fri Feb 20, 2026 2:04 am
I think you missed my question here, my Streetwise is running on 17 inch Adendum alloys and quite nice they are, I was looking to get a set of the Steel Wheels as fitted to the early base models i think. From the odd picture i've seen they were cream with 16 small holes and a small black centre trim...
by Bean66
Wed Feb 18, 2026 9:06 pm
Hi I'd be surprised if they weren't used on something else, after all why not use a wheel you already specced for something else, esp when there were car with steels as standard. Tho i must admit i'd not considered the space saver angle, esp as mine has a full sized alloy as a spare and its a 2005 c...
by Bean66
Sun Feb 15, 2026 12:34 am
Streetwise Wheels
Hi All Just out of curiosity really, though they look nice. Were the cream steel wheels fitted to the base Streetwise, so multi circular holes (16 I think) fitted to other Rovers 25's or 45's behind wheel covers, obvs in black. Thought it might be nice be nice to get a set and refurb them in cream. ...
by Bean66
Thu Sep 25, 2025 8:20 pm
Topic: K series misfire diagnosis
Re: K series misfire diagnosis
Hi
I was thinking along the same lines but wondered if there were any other common culprits on a K series.
So unless someone comes up with a code specific idea i'll put some Premium Unleaded in and give it a run about.
Cheers Bean
by Bean66
Wed Sep 24, 2025 7:21 pm
Hi All I've got an 03 TF 1.8 135 as well as my Streetwise and its got a fault and well its a K series so thought i'd ask here. Just its passed its MOT and drove there ok and passed the emissions test, but on the way home developed an obvious misfire I can feel and the engine light came on. Got mysel...
by Bean66
Mon Sep 22, 2025 8:56 pm
Topic: Battery charging Auto electrician advice needed
Re: Battery charging Auto electrician advice needed
Hi Keith Cheers for that. My car sits outside so attaching a battery charger means getting the extension out and putting it through the front door, which is the bit thats the pain and difficult to do for overnight charging or taking the battery off the car, more of a pain, esp as the front drivers d...
by Bean66
Sun Sep 21, 2025 1:53 am
Hi Keith Appreciate the comments. I do pretty much the same tho i'm not sure my battery lasts that long. I just wanted to get rid of the faff of getting the charger and extension cable out and setting it all up every couple of weeks, thats of course if i remember to do that before it won't start aga...
by Bean66
Tue Sep 16, 2025 4:31 pm
Hi All Slighhtly off the wall question to any knowlegable auto electricians out there. My 25SW battery keeps going flat. Reasonably simple reason, it generally does short journeys so not enough charging and can sit for weeks without being used. Now ages ago I saw a solar charger that purportedly plu...
by Bean66
Mon Jul 21, 2025 2:02 pm
Topic: Rover lock barrels
Re: Rover lock barrels
Hi All "MG's were traditionally somewhat designed around the high-volume parts bins after all!" Exactly what i was thinking, but not sure. I'll keep looking for a lock barrel, but sadly scrappys arn't what they were, so i'll repeat the request, anyone got a lock barrel with no key they don...
