Search found 5 matches
- Wed Apr 05, 2023 12:53 pm
- Topic: What is this number
What is this number
Hey, the head of my rover is different from the block and i found this number on the engine block, can this identify my engine or what it is?
- Tue Mar 14, 2023 1:46 pm
- Topic: Cold start issue 400 1999
Re: Cold start issue 400 1999
Sounds like the coolant temperature sensor to me: https://rimmerbros.com/Item--i-MEK100061 If the sensor has failed, the ECU uses a default setting that will allow the car to run without overfuelling, but it will not enrich (choke) enough to start from cold. :welcome I've changed the sensor and sti...
- Wed Mar 01, 2023 3:31 pm
Didn't know the ECU of 99 had that impact
- Wed Mar 01, 2023 3:00 pm
Yes, this happands when i start the car on the next day or even when im not using for like 10 hrs
What is that sensor?
- Wed Mar 01, 2023 2:14 pm
Hey, my car has a cold start issue, i've changed too many things and stil having the problem, i changed the spark plugs, spark cables , battery, injectors, belt distribution, filters ( fuel, oil, air), starter, butterfly valve i think thats it and already did a hole on fuel tank cap becouse it had v...
