Page 1 of 2
T Series Air Hoses
Posted: Thu Jan 11, 2018 11:01 pm
by Paul_1978_yorks
Hi all, how can I identify all the air hoses in the T series engine, whether these be larger hoses or thinner black tubes?
I still have a slightly wandering idle issue and when I was chatting with a mechanic, he suggested there could be a small air leak.
So I was thinking of changing what I needed to, but didn’t want to get confused with other hoses, eg coolant hoses!!
Re: T Series Air Hoses
Posted: Sun Jul 21, 2019 6:48 pm
by vaml73
Hello, good afternoon, I wanted to ask you a long time ago.
Did you solve the unstable idle?
I have the same problem.
It goes up low sometimes it stops it has me crazy
I wait for your answer
Posted: Sun Jul 21, 2019 7:11 pm
by Paul_1978_yorks
Yes I did. I cleaned the throttle body and vacuum hoses with carb cleaner.
I also found a small part on the back of manifold that should have been blanked off, but the small plastic. Cap had perished. I taped it up instead. )I will take a picture of the area and post, but next week as I am on holiday at the moment).
All these things resolved the issue.
Posted: Sun Aug 04, 2019 7:14 am
by vaml73
Hello good morning, thank you very much for your quick response, I hope those pictures.
Greetings good holiday.
Posted: Sun Aug 04, 2019 1:05 pm
Check the back of the throttle body, there is s cap that sits over one of the pipes. If not there, that is your air leak.
Posted: Sun Aug 04, 2019 9:41 pm
by vaml73
Hello good night, I have verified what you told me and the tube that goes to the ECU is connected.
Another tube that is connected to a pump can be?
and another exit that has a cap on,
In principle I think it's fine.
Also clean the acceleration body.
I have changed the idle sensor.
Also change the coolant temperature sensor.
Try adjusting the air inlet with the screw that has the acceleration body.
and finally adjust the throttle cable.
I have noticed some improvement but I still notice something unstable.
thanks greetings
Pd: how can I upload pictures?
Posted: Mon Aug 05, 2019 9:14 am
by Vinny1979
Posted: Mon Aug 05, 2019 8:41 pm
by vaml73
thank you very much I will try to upload photos to the forum
Posted: Wed Aug 07, 2019 10:04 pm
by vaml73
Posted: Wed Aug 07, 2019 10:10 pm
by vaml73
