Rover 200 & 400 Owners Club • rear drum to disc conversion
Page 1 of 3
Posted: Thu Feb 08, 2018 5:47 pm
by pkronic
as title says i wanna convert to all round discs as i will be increasing the power of my car and sooner or later will be going to track days so i want to get discs on the back for better brake cooling anyway has anyone got any ideas what cars rear calipers and everything will fit? also will i be able to get a unit that bolts straight on or will i need to source source conversion plates for the caliper carrier to bolt to?
Re: rear drum to disc conversion
Posted: Thu Feb 08, 2018 6:06 pm
oh the pain for such little increase in braking power.
Saying that, it looks better. But the calipers seize and the cables stretch ect.
So, on to what you need, basically the back end of a vvc coupe or turbo.
you will need:
rear trailing arms
hand brake cables
calipers
discs & pads
rear brake pipes
Your handbrake will suck, but it will look pretty and this coming from the guy who used all new kit. If you want i'll link to the section of my blog when i did it to my cabby.
Posted: Thu Feb 08, 2018 6:36 pm
by pkronic
yhh that would be call and its not for looks or power so much just when ive been to track days in cars with drums once they get hot they arnt effective where as discs cool off faster due to not being enclosed
Posted: Thu Feb 08, 2018 6:58 pm
your call :laughing2
i think they look pretty, not arsed how they work :laughing2
http://218vvccabriolet.blogspot.co.uk/2 ... rsion.html
Posted: Thu Feb 08, 2018 8:10 pm
by ROVER Cabby
Do this, looks pretty, nuff sed ! :laughing2 :tt2 :slapme
Posted: Thu Feb 08, 2018 8:15 pm
by Johnny 216GSi
In theory at least, the trailing arms can stay but you need disc spindles. I assume these come with the calliper carrier mount points, etc.
But as Dist said, everything has to be sourced - nothing is common between drum and disc brakes.
Posted: Thu Feb 08, 2018 8:17 pm
you can't use use the drum arms at all, there are no additional holes for holding the caliper carriers or anything.
As per my blog post i pulled them apart hoping to be able to keep them but nothing was usable.
Posted: Thu Feb 08, 2018 8:18 pm
by JOHNDQ
Get the discs on and move away from the 1980's :laughing2 Just find a ZS 180 breaking and get everything you need
Posted: Thu Feb 08, 2018 8:21 pm
by Johnny 216GSi
1234dist wrote: Thu Feb 08, 2018 6:06 pm Your handbrake will suck...
Why does the handbrake suck? Just curious...
Posted: Thu Feb 08, 2018 8:27 pm
It just doesn't bite nearly as tight as the drum did (based on my cabby).
Still more than enough but i bet i could have done a handbrake turn on drums, no chance on the discs and all mine where new kit, caliper, pad, disc and handbrake cable.
