Rover 200 & 400 Owners Club • Hydraulic lifters
Page 1 of 2
Hydraulic lifters
Posted: Wed Feb 05, 2020 10:43 pm
by Jamesridgway1994
Done a headgaskit and timing belt the other month along withn new water pump, thermostat pulleys new valve stem seals new cam stem seals, after putting it back together I found that a couple of the hydraulic lifters were knackered so I brought 16 new ones! Once the tourer was put back together with new lifters in she was still a bit tappy so few weeks later i changed out the oil and I thought I'd put some thicker oil in because she only slightly taps once if been driving her for 30+ mins so I thought maybe the oil was thinning out once she get up to temp so I put some 20w50 mineral oil in, thicc stuff *laughs* and it done the trick for about 2weeks and now it only slightly taps after driving for 1 hour *laughs* , thinking maybe I got a dud lifter? Should I buy some new ones? Thoughts?
Re: Hydraulic lifters
Posted: Thu Feb 06, 2020 6:29 am
You should have soaked your new tappers in 10/40 semi for a day or so prior to fitting to make sure they were full of oil prior to fitting. The engine was only ever designed for 10/40 based on being in England’s tropical environment.
Did you also line up the oil feed holes in the tappet to those in the head or did you just drop them in?
Posted: Thu Feb 06, 2020 6:13 pm
by Jamesridgway1994
I soaked them in oil and aligned them that's why I'm still confused...
Posted: Sat Feb 08, 2020 3:54 pm
by ROVER Cabby
Because ROVER, the end. :laughing2
Mine have been like this since 2003 when it was 18 months old, finally silenced last week. :slapme
Posted: Sat Feb 08, 2020 4:46 pm
by JOHNDQ
If this only happened still done the head have you sealed the cam carrier with the correct sealant
Posted: Sat Feb 08, 2020 5:02 pm
by Jamesridgway1994
Its only done it since the work been done but I notice it more than other people but to me it sound like 1 lifter on the intake side right next to the belt like the first lifter, I used the red rtv sealent stuff
Posted: Sat Feb 08, 2020 5:10 pm
by Jamesridgway1994
I reckon its something silly because its not that loud and tbf the alternator belt moving is about the same kind of volume, but its just a ball ache to take it apart to look at 1 single lifter *laughs*
Posted: Sat Feb 08, 2020 5:13 pm
by Jamesridgway1994
ROVER-25X wrote: Sat Feb 08, 2020 3:54 pm Because ROVER, the end. :laughing2
What got yours to be quiet?
Posted: Sat Feb 08, 2020 6:20 pm
by JOHNDQ
If you used RTV you got a major problem :o
Posted: Sat Feb 08, 2020 6:48 pm
by Jamesridgway1994
JOHNDQ wrote: Sat Feb 08, 2020 6:20 pm If you used RTV you got a major problem :o
I think I did.. Can check Monday at work but go on..
