Rover 200 & 400 Owners Club • Exhaust Info needed
Page 1 of 2
Exhaust Info needed
Posted: Wed Dec 08, 2021 11:47 pm
by Axorman
Evening,
I have an October 92 registered 216 GTI DOHC, it's a 5 door, in need of a centre exhaust box, needed as MOT in January and it's started blowing, any help in locating one or part numbers would be helpful, struggling to find online
Ron
Re: Exhaust Info needed
Posted: Thu Dec 09, 2021 2:14 pm
by JEASPEKE
I have 1990 216 GTI DOHC and tried last year, all sources are NLA on mid section, you may have more luck with back box from a secondary supplier but Klarius the biggest EU manufacturer said will these not be re manufactured ever. In the end I had a garage weld and plate mine, should last 20 years as only used in summer and garaged all year
You could go SS route - that is an option others have taken.
Good luck
Posted: Thu Dec 09, 2021 4:59 pm
by Paul_1978_yorks
I’d get a stainless steel bespoke one made up. Try Longlife.co.uk
Posted: Thu Dec 09, 2021 7:36 pm
by 220 GSi turbo
Could you use the later (catalyst type) mid section, using a 'decat' pipe to make up the difference in length?
Posted: Thu Dec 09, 2021 8:27 pm
Anyone got a pic of how it should look. I’ve got some new pipe work which might do the job.
Posted: Thu Dec 09, 2021 9:44 pm
by JEASPEKE
This is the layout for an early 216 GTi 5 Door Exhaust, taken from Klarius' parts catalogue (No longer available from them):
Posted: Thu Dec 09, 2021 9:52 pm
by JEASPEKE
Pictures of mid-section on my 5 door 216GTi, and fittings.
Hope these help.
Posted: Thu Dec 09, 2021 11:26 pm
by Axorman
Thanks, so limited options then, either try and get this one repaired, or go stainless.
As I need only the mid section, would using the shorter Cat mid section, and adding a section of pipe work?
As I can't do the work myself will speak to the garage that looks after my other car
Ron
Posted: Thu Dec 09, 2021 11:28 pm
by StubbornPatriot
Somebody's selling a centre section on Ebay that they say fits both the 216 GSi & 216 GTi. Their diagram looks different to John's photo though. Afraid I don't know the difference, or whether it is suitable.
https://www.ebay.co.uk/itm/175057299493 ... Swm3paInX3
Posted: Fri Dec 10, 2021 7:52 am
by JEASPEKE
I think that is for Single cam 1.6 in 3 door GTi, box might be in the wrong place to fit the 5 door.
