Rover 200 & 400 Owners Club • Number in boot floor
Posted: Wed Mar 22, 2023 2:23 pm
by RMS1974
Good afternoon,
I'm considering a tow bar for the Cabriolet, having taken everything out of the boot I found this number on the nearside above the chassis rail area:- 2B336J 0059754
It's not the VIN, could anyone please shed any light please?
Re: Number in boot floor
Posted: Wed Mar 22, 2023 3:42 pm
by GTiJohn
That'll be the body sequence number, which was assigned to the bodyshell during the assembly process in West Works and before paint.
It is necessary to have a reference number so that if any problems are recognised, such as a faulty weld gun, a 'good after' number was needed and a sweep performed between that and the previous good number.
Destructive tests were performed on several critical sub-assemblies pulled from the line to check but production continued while the checks were done. Failure was very infrequent, as you can imagine, otherwise you have to rework, or lose, a lot of bodies!
The VIN stamp was applied on the CAB1 assembly line and the body becomes a car :D
Posted: Wed Mar 22, 2023 3:56 pm
by RMS1974
Thanks very much for the explanation John.
Regards
