Sagging Drivers Door on Cabriolet - Cause?
Post by ROVER Cabby »
My Drivers door on the Cabby has some slop to it, seems to catch the striker hard and needs a little lift to engage properly.
I had a look at the components on Rimmers, but does anyone know the exact cause and solution before I do something dumb like ordering all new hinges and pins etc. :slapme
Although, a new check strap wouldn't go a miss. :sleep
4 - Upper Hinge (Out of Stock)
5 - Lower Hinge
8 - Check Strap
10 - Check Strap Pin
2001 ROVER 25 - 1.4 Impression S - Been sat since 2018
1997 ROVER Cabriolet - 1.6 K-Series - Now back home in the New Garage, still mouldy, but dry!
2012 VAUXHALL ASTRA - 1.7CDTi EcoTec - Daily Oil Leaker
2007 VAUXHALL TIGRA - 1.4 TwinTop - No MOT
Re: Sagging Drivers Door on Cabriolet - Cause?
Have you tried to watch the hinge while picking up the door?
Is it frameless? perhaps try taking up the slop with a scissor jack with a block under the door bottom?
Post by crepello »
Hinges for 3-dr have been NLA for some years, unless some more have turned up since I looked. My 3-dr hatchback
had the same problem. As these doors are longer, there's more load on the hinge pins than in the 4- & 5-dr.
I diagnosed it as wear at the hinge pins, and lifted a door off to investigate. This is possible without unbolting the
hinges if the door is opened wide enough. On mine, the pins weren't obviously worn, but the mating holes were. I
discovered that a quality design job had been done, and the holes were bushed with oilite bushings. It was possible
to drift the bushes out for replacement. Unfortunately, I couldn't trace exact replacements, and ended up with a
PTFE-lined equivalent, similar to this.
Note, I'm not sure at this distance in time that this is the exact size I used.
Maybe it would be worth taking a chance on a 5-door hinge and extracting the bushes from it :idea:
1995 220GSi Turbo: owned for 22 years
I have good hinges for cabriolet and door straps
crepello wrote: Tue May 02, 2023 11:53 amOn mine, the pins weren't obviously worn, but the mating holes were. I
It was possible to drift the bushes out for replacement. Unfortunately, I couldn't trace exact replacements, and ended up with a
Interesting, ive saved that site, they are cheap enough, it's a ways off yet, but once stripped i'll get the calipers out and check sizes.
Did it fix your issue?
220 GSi turbo wrote: Tue May 02, 2023 8:32 pm Maybe it would be worth taking a chance on a 5-door hinge and extracting the bushes from it :idea:
Another interesting idea, do you think that could be feasable?
961tat wrote: Tue May 02, 2023 8:34 pm I have good hinges for cabriolet and door straps
My lack of surprise can't be shown via typing here *laughs*. :laughing2
Post by crepello »
ROVER Cabby wrote: Sat May 06, 2023 7:47 pm Did it fix your issue?
Pretty much!
I did similar to the windscreen wiper spindle bushes to stop the arms catching the bonnet edge as it
was lifted. Not so successful, I think the arms were actually slightly curled with age.
Keeps my options open then. :)
