K Series Cams
Kriss707
K Series Cams
Post by Kriss707 »
Hi All
Doing an Engine swap & the replacement engine is older than the blown one.
It's a 2001 Rover 45 1.6, the replacement is from a 1998 Rover 216, obviously the replacement isn't the Wasted Spark K Series so doesn't have the CPS Lobe.
Question is can I just change the one Cam from the blown engine that has the CPS Lobe, as the replacement is Coil & Dizzy, or do I have to change both as a matched pair ?
The Cams are the same part number, which I know is just the Cast number. The Cam Lift is the same & the Profile is the same, I checked using a good quality 'Mimic' & Digital Vernier Calliper.
TIA 😁
Re: K Series Cams
Just replace inlet I would polish any marks on the journals surface on the new cam and old hydraulic lifters 2000 wet and dry but wouldn't touch to ally carrier and check the endfloat .
