SEI 214 three door
george@gmpy.co.uk
SEI 214 three door
Post by george@gmpy.co.uk »
Hi all, Help…. having problems with emissions had a new catalytic converter and garage does it seem to be able to find a problem any thoughts would be appreciated new petrol full tank too weeks ago ten miles since, to mot garage where it failed on emissions test, fitted new catalytic converter,
George
Re: SEI 214 three door
Which parts of the emissions test are over the limits?
Post by Paul_1978_yorks »
Have you tried adding fuel cleaner, eg Redex or Forte or similar, and taking it on a good long drive? This should help before the next emissions test. And the emissions are best tested when the engine is hot :)
1996-N Charcoal 214 SEi
2010 Volvo V50 2.0 SE Lux
214 SEi x3, 216 SLi, 216 Cabriolet, 416 GSi, 420 GSi Tourer, 25, 45, 75
MatthewL
Post by MatthewL »
I had shocking emissions on my car - lambda sensor which is screwed into the exhaust manifold was shot. Apparently they settle at 0.45v output when the car is warm. Mine was up and down which apparently shows it is duff. Swapped it for a new one and it sailed through the emission test. Was hard getting it out. Required an impact gun!
GTiJohn wrote: Sat Feb 03, 2024 6:22 pm Which parts of the emissions test are over the limits?
This - we need the figures to assist accurately, please :D
Rover 200Vi
Rover 214SEI
Lotus Elise S
Toyota GR86
MatthewL wrote: Sun Feb 04, 2024 9:14 pm I had shocking emissions on my car - lambda sensor which is screwed into the exhaust manifold was shot. Apparently they settle at 0.45v output when the car is warm. Mine was up and down which apparently shows it is duff. Swapped it for a new one and it sailed through the emission test. Was hard getting it out. Required an impact gun!
A healthy pre-cat lambda sensor should switch between 0.1 - 0.9v approx. at least once a second when the engine and sensor are both at operating temperature.
Rover 200Vi
Rover 214SEI
Lotus Elise S
Toyota GR86
MatthewL
Post by MatthewL »
Apologies must have been the other way round. I recall it was not right. It messed with the emissions terribly.
george@gmpy.co.uk
Hi re fails
Fast idle
CO 1.43%
HC 226 PPM
Second Fast idle
CO 1.69%
HC 215 PPM
What are the lambda readings?
Rover 200Vi
Rover 214SEI
Lotus Elise S
Toyota GR86
One thing's for sure, that new catalytic converter needs to come off if it hasn't solved the problem and the original 1995 item with a scrap value of many £££££££s need to go back on! (The new one is likely to be an inferior aftermarket item that is very unlikely to last as long as an original).
1995 220GSi Turbo: owned for 22 years
