I'm in need of a clear picture of the ECU pin numbers and wire colors for the L series (2004)
when I rebuilt the van i had a doner car with working air con, and swapped it to the van, however may have a wire or 2 in the wrong place, the air con holds pressure and works if i manual feed the clutch relay.
