Rover 214 Emissions
Posted: Fri Jul 05, 2024 3:59 pm
I have had real trouble getting my 214 SEi through the MOT due to emissions. It eventually passed this afternoon but only just.
The car has 55,000 on the clock and is in good mechanical order with no faults.
In December 2020 at 49,000 I had a full stainless steel exhaust fitted. Since then I have done 6,000 miles. I have had no emissions problems in the past.
It failed on the emissions and the main problem area was CO on fast idle. Lambda reading were not great either. Car was tested whist hot.
The MOT tester suspected a "cheap cat" and recommended I take it back to the specialist exchaust centre. I did this and they swapped the cat at cost price, unfortunately this made no difference.
I then had the Lambda sensor swapped - this resolved the Lambda readings, but not the fast idle CO.
Struggling for ideas, I had a look round on the forums and discovered a few posts about the lambda sensor relay. I opened up the fuse box under the bonnet and found 5 fuses and an empty slot. It appeared the lambda sensor relay was MISSING (I don't know if is normal for this not to be present). I found one in my spares box and fitted it in the empty slot. However this didn't make any different and it still failed the re-rest.
Finally he gave it another go, and the emissions test passed (only just) but I don't want to go through this rigmarole every year.
The tester still thinks the problem is a "cheap cat" and that a better quality cat would resolve.
What are people's thoughts? What would be the things to look at for a high CO reading at fast idle?
