Can anyone tell what these parts are suppose to be fitted to?
LJR10126 - Rear Timing Belt Cover
LJR10128 - Cover-timing belt - Lower
LJR10126 appears twice on ebay but with different vehicle application. Both look like the same as the one off my 416 GTi with Honda D16 DOHC engine so I'm wondering if the first link has incorrect information on it . The second ebay link suggests it is for my vehicle. The complete Honda part number you can see in the moulding is also different from the one stamped in the part on my vehicle, although the start of it 11840 is correct
1st Ebay Link
https://www.ebay.co.uk/itm/354733606194 ... name=11051
2nd Ebay Link
https://www.ebay.co.uk/itm/402225130767
Same applies to LJR10128 it looks exactly as per the one of my car but the reference given applies to a later VIN number.
This is being sold by MGLR,
https://mglrparts.co.uk/products/cover- ... PPxAdPaLtX
Can anyone clarify these part numbers for me?
Many thanks
Timing Covers Part Number confusion!
- 220 GSi turbo
Re: Timing Covers Part Number confusion!
I don't know if you are already aware of the website I have linked to here: https://www.parts-honda.uk/honda-cars/CONCERTO but it can be quite useful when researching original Honda part numbers for our cars (even though many of the parts are NLA!)
Yes I have used that.
I get a bit confused as the possible models that used the same engine.
Tried to order some bits from there but although it says UK it’s obviously not in the UK as you have to spend £165
If you PM me the VIN and year of your car, I'll check the parts microfiche for the correct numbers for you.
I’ve PM’d you.
Appreciate you checking for me.
The current ones are usable but the outer one I’ve had to repair one of the lugs so not sure how well it will last.
I've responded to your PM - hopefully it contains the info you need. As a footnote, I've had a search on the registered dealer database and nobody is showing the correct number in stock, unfortunately, so it'll be a case of scouring eBay & Google for a hit. There's no supersession of the part number listed.
Thanks for your help.
Looks like my search continues
