how to enter an eka code?
xadowbg
Post by xadowbg »
hi can any one tell me how can i enter the eka code on my cabbie...?? step by step please... :blushing
agw_01
Re: how to enter an eka code?
Post by agw_01 »
Unlock the car and then open and close the drivers door.
Let's say the code is 1234.
Key in, turn left once. Return to the center.
Turn right twice, return to center.
Turn left three times, return to center.
See where this is going...
Turn right four times, return to center.
The alarm LED should flash for a second. If the code is wrong, the horn will chirp. Open and close the door to reset.
If that doesn't work, try turning the key the opposite way... i.e. right once, left twice etc
xadowbg
Post by xadowbg »
the problem is that my fob is gone so when i unlock the car whit the key the alarm gets on and the neighbors are not happy... i cant use the car !!!!!! my girl wil kil me this time for sure :scared :slapme
agw_01
Post by agw_01 »
The alarm should still de-activate from the key.
There's a little switch just next to the barrel inside the door. The connector for this could have come off.
You're going to have to get the bonnet open with the alarm going off and quickly disconnect the battery to stop the horns blaring, giving you some time to have a look behind the door card.
xadowbg
Post by xadowbg »
so i have to get off the door trim and look inside the door near the barrel thingy.?
xadowbg
Post by xadowbg »
you were right man!! there was a tiny switch that got off near the barrel i got some super glue and got it in again. that why i couldn't get my eka code to work no it is ok i don't need a fob any more!!!! :clapping :*laughs* :wink3
lewp91
Post by lewp91 »
you could have just used the key in the passenger side to turn off the alarm...
my drivers side alarm switch was short c'd by a friend when we were filling aftermarket c/l :/
so if i lock by the pass and unlock the drivers the c/l dont work and he alarm goes off!!! :p
xadowbg
Post by xadowbg »
ermmm on passenger door there is no hole for the key the trim has the hole but underneat its sealed whit a metal plate
lewp91
Post by lewp91 »
oh bugger...
forgot it was a cabbie...
guess if you cant fix it right away you can drop the door pins and close the doors not activating the alarm :p??
xadowbg
Post by xadowbg »
or make a hole in the roof and get in ! :tongue
