drivers door lock
drivers door lock
1998 216 coupe. door lock button has jammed in the locked position, door only opens from inside handle, cable controlled, can't seem to release the rod from door handle to lock so i can get lock out to have good look at it. Any advice would be very helpful . thanks
Re: drivers door lock
Buy some plastic trim tools & remove the door card. try to be gentle when prising the card away from the plastic locating dowels in the door frame.
door card is off. rod from handle to lock is my main problem. don't want to use a drift and hammer in case it won't go back togetherMr Teddy Bear wrote: ↑Wed Apr 05, 2023 2:46 pm Buy some plastic trim tools & remove the door card. try to be gentle when prising the card away from the plastic locating dowels in the door frame.
