Remote locking
RMS1974
Remote locking
Post by RMS1974 »
Good evening, a smallish problem has raised its head.
When I bought the car it had 2 sets of original keys and an original (I believe) plipper, unfortunately there were no rubber buttons over the switch innards!
I have now made some buttons utilising a cheap case from eBay.
The situation is, the central locking works on both doors when opening & closing using the key in the drivers door, & by inside using the door knob.
When outside the car, the plipper glows red & green with the appropriate button, but only triggers the passenger door, opening & closing.
I've had a look on the forum and the "Central Locking Unit" is mentioned a few times, is this likely to be the case? and if so where does it hide please.
The plipper is a Valeo.
Re: Remote locking
It sounds as if you have the infrared immobiliser system/fob. Best person to talk to is 220GSiTurbo who is otherwise known as Paul Vincent. The later fobs don't have any LED's.
There is a modification available via the Coupe Club to upgrade the alarm to the later system.
RMS1974
Re: Remote locking
Post by RMS1974 »
Thank you.
rjessett
Re: Remote locking
Post by rjessett »
Yes - we have developed a plug an play kit to replace the Infrared system on earlier cars.
Details are here:- https://www.rover200.org.uk/forums/topi ... 9&start=10
We will have a few of the kits on the Rover Coupe Owners Club stand at the Pride of Longbridge next week
RMS1974
Re: Remote locking
Post by RMS1974 »
Again, thanks for the reply and link.
It's something for the future methinks, I was hoping that the solution would be something within the door area that could be repaired, or swapped out at a relatively small cost.
I can live with locking using the door for the foreseeable, as it secures the car and the alarm functions.
Cost's wise I have to factor in a cambelt & water pump change in the next month as it is long overdue.
