LR013017 - Brake master cylinder upgrade?
Thomas Loveridge
Post by Thomas Loveridge »
Hi all,
I wanted to ask if anyone has used this master cylinder as an upgrade for the 220 Coupe?
I want to replace mine with a 1" bore from a land rover, I've seen it mentioned a few times but I'm not 100% on what bmc to get and I can't seem to find if this one has a 1" bore or not. I would like to avoid having to modify the original piping if possible.
Rimmer Bros link: https://rimmerbros.com/Item--i-LR013017P1
Thomas Loveridge - New Zealand
1994 Rover 220 Turbo
2001 Rover 75 2.5L Connoisseur
Evil C
Re: LR013017 - Brake master cylinder upgrade?
Post by Evil C »
The specs on Autodoc (https://www.autodoc.co.uk/car-parts/oem/lr013017) for LR013017 gives the bore as 27mm. The 'P' at the end of the part number you have linked to simply denotes that it is a pattern part rather than genuine LR, but I would expect it to be the same.
Thomas Loveridge
Evil C wrote: Sun Mar 24, 2024 2:14 pm The specs on Autodoc (https://www.autodoc.co.uk/car-parts/oem/lr013017) for LR013017 gives the bore as 27mm. The 'P' at the end of the part number you have linked to simply denotes that it is a pattern part rather than genuine LR, but I would expect it to be the same.
That's great to know thank you! It was more that I just didn't want to bend the brake hoses to fit the master cylinder with the outlets on the other side. Looks like I'll be getting this one then.
Post by JOHNDQ »
I use a LR Defender TD5 non ABS one on my cars just made new brake lines up
214 Sprint track car
216 GTi track car
216 GTi DOHC
Vinny1979
Post by Vinny1979 »
To add I have also used a defender one on mine. However mine is an abs version
220 gsi turbo
It’s quite a tight fit
But works
Thomas Loveridge
Vinny1979 wrote: Sat Mar 30, 2024 5:15 pm To add I have also used a defender one on mine. However mine is an abs version
220 gsi turbo
But works
That's good to know! How would you describe the brake feel now? Are you running the stock calipers as well?
Thomas Loveridge
JOHNDQ wrote: Thu Mar 28, 2024 5:56 pm I use a LR Defender TD5 non ABS one on my cars just made new brake lines up
Yes I've seen the TD5 mentioned, I would just like to avoid modifying the lines. If the ABS ones work I'd rather use them.
Waynes220gti
Post by Waynes220gti »
Morning did anyone managed to fit this master cylinder as I’ve bought one and bolt holes are not in same orientation as ones on my original rover one
