Then i found some splits that needed welding up. Think the tube is made of flat, that is bent into a curve and welded and it slit along the weld, so i cleaned it off and welded it back up.
Then found some grot behind a bracket so opened it up and used a hacksaw to clean it up. Then left them to soak all weekedn in Bilt Hamber Deox C rust killer.
Made serious progress today. I spent ages prepping the slam panel. I de-rusted the underside, painted it in Hydrate 80, then bonda zinc primer, then etch primer. Left it on the radiator to dry.
Then painted the underside in metallic green. Only doing the underside as all the top will be done properly by the bodyshop. The underside will be difficult to get to once it is welded in, hence me doing it now. I also did the rear side of the bonnent latch stiffener and the front bumper mounts.
