Rover 200 & 400 Owners Club • Rover 416 GTI Auto - Restoring an old friend - Page 8
Page 8 of 12
Posted: Thu Mar 24, 2022 8:44 pm
Johns coupe we are restoring had piston rings seized to the bores after just 20yr in the garage…*laughs*
Posted: Thu Mar 24, 2022 9:29 pm
by Plodder
RoverRevival wrote: Thu Mar 24, 2022 8:44 pm Johns coupe we are restoring had piston rings seized to the bores after just 20yr in the garage…*laughs*
Sounds as if RoverRiggots potential purchase restoration might need the same treatment as Johns coupe
Posted: Thu Mar 24, 2022 9:38 pm
One day john will show the pics on how we fixed it…*laughs*
Posted: Tue Mar 29, 2022 1:15 pm
by RoverRiggott
Plodder wrote: Thu Mar 24, 2022 9:29 pm
I do hope not as that may decide its fate, unless anyone has a replacement engine hanging around! The car is being recovered next week, so will know more shortly after
Posted: Tue Mar 29, 2022 1:56 pm
by Plodder
Good luck, fingers crossed recommissioning goes smoothly.
Keep us informed of progress
Posted: Sun May 15, 2022 10:10 pm
by Plodder
Well you'd think that a good deal of rust proofing and a good amount of welding work I'd be on top of the rust, no chance!
Been doing a bit of maintenance, adjusting the value clearances, changing oils etc , etc.
Decided to clean the three way rubber moulding that fits between the plastic air intake pipe and the air filter box.
Refitting it was easier with the filter box removed. But one of the bolts for the filter box is under the fuse box so I decided it was easier to remove this to gain access.
The joint between the top front suspension mount and the inner wing panels is now visible.
The mastic on this joint looked like it was hiding something. Sure enough a large lump of it came away with a little prod of a screwdriver.
Further prodding with the screwdriver revealed a corroded area about 20mm square with a tiny pin hole going all the way through.
The rest of the mastic on the upper part of the joint came away easily but whilst there was a bit surface discolouring there is no surface pitting - thank goodness.
Currently coated it with some Bilt Hamber Hydrate 80 to stop progress of the rust whilst I decide what to do
I guess I should be thankful I spotted it now rather then later when the panels were more significantly corroded.
Seems like a very odd place to rust but this panel was repaired after significant front off-side accident damage 25 years ago, just after I brought the car.
So maybe the panels weren't closed properly underneath or have opened up over time . Its just beyond the wheel arch liner so it's exposed to some of the elements from the otherside.
I'm thinking anything other than a proper repair will return to bite me later on.
I was looking for somewhere to do the bodywork in South Devon anyway so now I've got another reason to get on with this task.
Oh as for the valve clearances, well the Haynes manual says you have to do this every year or 12,000 miles. My records show its not been done for 25 years or 100K miles (Sloppy very sloppy :laughing2 )
I had 2 exhaust valve clearances 0.025mm down on the minimum clearance and 2 inlet valve clearances up 0.025mm on the maximum clearance - not too bad.
As soon as the new gasket sealant is delivered, to do the camshaft cover gasket, I'll be able to see if it's made any difference
Posted: Mon May 16, 2022 7:50 am
by James3990
Such a strange place to rust, I can only guess water is getting between panels from inside your wheel arch causing it to rot from the outside in.
Posted: Tue May 17, 2022 3:21 pm
by Plodder
The odd places this car has rusted badly continues to amaze me. Mind you if I was a car I’d probably have a few rusty spots as well🤣
Posted: Sat May 21, 2022 10:41 am
by henryiett
I love the red, because it js a vivid red the paint just pops
Posted: Mon Jun 27, 2022 7:15 pm
by Plodder
Well finally got all the maintenance stuff complete.
Amazing the difference adjusting a couple of the valve clearances has made to to start up.
Eagerly fires up without any of the hesitation it had previously.
Used a BGA Rocker Cover Gasket Kit RK6301 which also came with 4 off spark plug tube seals and some other seals . Some of which didn't seem to fit anywhere on my engine.
Hoping the new spark plug tube seals (hope that's the right name for them :laughing2 )will stop the oil leaks I had into the spark plug tubes.
The new seals were 6.5mm thick whilst the ones I removed , which might have been the originals, were 5.5mm thick so the old seals had definitely compressed down a bit during their life.
Time now to enjoy some shows and a bit of driving - and find someone to fix that bit of rust.
