420GSI Tourer various fixes
MatthewL
Re: 420GSI Tourer various fixes
Post by MatthewL »
With the weather and darkness I’ve not been doing much except mopping up what I believe is 7 simultaneous leaks into the boot. 2 fixed, 5 to go.
I’m the meantime I had to take out the headlining which had been lovingly stapled up - you can see if you zoom on the picture.
Anyway, I got the headboard out ok and used 3metres of AS-Trim Oxford Titanium Brushed Foam-Backed Headlining and 3 full tins of hi temp glue. It looks a great colour match. I hope it’ll last ok. The board had gone a bit soft on the underside side I assume from the original glue but it cleaned up ok and seems to stick firmly.
I’ll refit the headboard when I have fixed 5 more leaks. I’ve also had to fit a new radio after the old one I had died which does at least sound lovely with new speakers fitted.
Matthew
Post by Topcat Tomcat »
The finished result looks really good. Perhaps I need pluck up courage to finish mine off!
Don't leave it 'till March...
I tried to refit mine on a windy day once.
MatthewL
Post by MatthewL »
Haha yeah I can imagine one gust and that oh-so-solid cardboard would be off!
It was quite a satisfying job really - you should go do it Tomcat! Well worth doing - I just hope I prepped the board correctly else it’ll not last as long as the original … which didn’t evidently last all that long anyway
crepello wrote: Tue Jan 18, 2022 1:21 pm Don't leave it 'till March...
MatthewL wrote: Tue Jan 18, 2022 1:48 pm It was quite a satisfying job really - you should go do it Tomcat! Well worth doing - I just hope I prepped the board correctly else it’ll not last as long as the original … which didn’t evidently last all that long anyway
I will have to persevere with removing the sticky remains of the old glue. I did find the small packet of alcohol wipes I had in a Hotel bedroom, worked pretty well. I'll have to have another go at finding some more.
MatthewL wrote: Tue Jan 18, 2022 1:48 pm Well worth doing - I just hope I prepped the board correctly else it’ll not last as long as the original … which didn’t evidently last all that long anyway
It wasn't the prep or the adhesive which failed though - it was the (probably) polyurethane foam
backing of the cloth decomposing. Your seat cushions are probably shedding yellow dust by the
same process.
MatthewL
Post by MatthewL »
Yeah the foam and glue had reacted and the cloth long since separated from the foam. I just used my fingers to rub off the foam and glue them finished the rest off with a dry scrubbing brush. After that I used a little thinners to remove residue but it was still weirdly soft feeling. Normally I use white spirit to get glue off as it’s awesome for that but it leaves a slimy residue. Ok on metal when you can wipe it off after but I reckon bad on card.
Plodder
Post by Plodder »
Well done looks like you’ve done a nice job.
Need to get some material for mine and get it done too. Just need to get some samples from the different suppliers. Alternatively I might just cut a piece of the headlining out and take it to all the trade stands at the next Resto show at the NEC🤣
1991 Rover 416 GTi Auto - Flame Red - Owned since Aug 97 :)
MatthewL
Post by MatthewL »
Plodder wrote: Wed Jan 19, 2022 12:06 pm Well done looks like you’ve done a nice job.
It’s about £12 with postage to get then from AS trim. If you private message me I’ll drop them in the post to you for nowt if you promise to return them. I think the titanium one is a lovely match for my car. Almost indistinguishable from the strip surrounding the sunroof.
MatthewL
Post by MatthewL »
Anyone know much about horns? I press the button, there’s a click mouse inside the car (relay i assume), fuse hasn’t blown. Any way of checking horns without taking the bumper off?
