Just make sure the neighbours are inside and their windows are closed before you start swearing
Or put your Santa costume on so they don't know who it is
Actually, perhaps taping a sort of tapered section to the front of the plug may help getting it down the tailgate side pillar. It may also be possible to tape the plug to the loom at a right angle for the "pull" if the side-on cross section is smaller than the front-on one is. Depends how flat the wires bend I suppose.220 GSi turbo wrote: ↑Thu Dec 07, 2023 9:24 pm Taping a stiff wire to the end before you remove it can help, as it then not only gives you something to pull the new one in with, but it can also help with freeing it if it snags along the way.
