The 420GSiT has gone...
Re: The 420GSiT has gone...
#76 Post by GTiJohn » Fri Apr 02, 2021 6:55 pm
Definitely a long-term project :clapping
Good to have you around again :cool
Smithy
Club President
#77 Post by Smithy » Fri Apr 02, 2021 8:12 pm
It is looking better than my 220. Mine needs an engine.
Rover 220 GTi Turbo.
#78 Post by RoverRevival » Sat Apr 03, 2021 8:49 am
I have a block sat around doing nothing if you need one, probably got some heads too
216 ronda coupe
& C3
tompinney
#79 Post by tompinney » Tue Apr 06, 2021 11:47 am
richard moss wrote: Can you give me the name of the cleaner that you use in the engine bay, because it looked amazing?
I use a mixture of products Richard. I use any old engine degreaser product, such as Carplan Engine Degreaser. for the painted and exposed metal surfaces predominantly. On the plastics/rubbers I pre-soak in a strong solution of Meguiars Super Degreaser and then scrub it using a stong solution of Meguiars APC. Once its all hosed off and dry I used Autoglym Super resin polish on the painted surfaces followed up with a spray on paint selant (not sure what I used on that occasion) and the plastics and rubber I use a liberal coat of 303 Aeorspace Protectant; leave it to soak in for a few minutes and then use a dry microfibre cloth to soak up any excess.
kevinwillis wrote: Apart from some oil leaks and 200,000 of ware and tier what are the main problems with the engine and what is the reasoning behind swopping the engines for the rebuild. and loosing the matching car and engine mileage?
Oil leaks would be an understatement Kevin. It burns oil almost as fast a fuel and leaves and epic smokescreen behind it when driving. The bores are very badly glazed so much so that there is no evidence of any honing marks left, the valve guides are shot which is is cause the the main oil leak due to premature wear of stem seals. I've been through two sets of seals in about 6000 miles; I thought the first set from ebay were defective so bought genuine Rover the second time around but they have resulted in the same symptom over time. I'm also pretty sure the crank would benefit from a new set of bearings by this stage. All in all it needs a complete strip down and rebuild which I don't have the time for right if I want to get the car mobile again this year. As I said in the original post the plan is to ultimatlely get the original engine put back in but that will have to wait until I have time and space to do it right. At this stage with it having been off the road for for fast approaching eight years I just want it out of the garage and usable.
Tom
Above all, it's a Rover!
-1993 420GSi Sport Turbo (The 'Rumm Chuff' :))
#80 Post by richard moss » Fri Apr 09, 2021 10:39 pm
Thank you
James3990
#81 Post by James3990 » Sat Apr 10, 2021 12:07 am
Great to see an update on this legendary car :cool
Rover 220 Coupe Turbo
Rover 220 Coupe Turbo Racer
Vinny1979
#82 Post by Vinny1979 » Sat Apr 17, 2021 6:57 pm
Wow. A car thats been off the road longer than mine ( was) :laughing2
henryiett
#83 Post by henryiett » Fri Jun 04, 2021 6:12 pm
Mine has been off the road since 2000
Rover 214si 1990
