Thanks for that sounds like a valid reason I'll assume I never had one and move on to something more importantMontegoman wrote: ↑Sat Nov 12, 2022 7:57 pm I think you will find that the panel on the o/s is there to protect the lock mechanism rather than look good.
Rover 416 GTI Auto - Restoring an old friend
Not made much progress since the last update having finally moved out of rented accommodation.
I now have a garage
But it's full of everyone else's stuff rather than car stuff
Including a lathe acquired whilst clearing my Dad's garage.
I'm sure it'll be useful, and safe, once I've sorted the 70+ year old motor wiring
Fitted the replacement seat belt buckle so now have a matched set again.
Finally got the rusty joint on the offside suspension turret repaired at a company called AM Restoration in Plympton. Not big into Rovers but are into Triumphs, particularly Stags.
https://amrestorations.co.uk/gallery/
Repair was painted rather than sprayed as it kept the price down and it is hidden under the fuse box on a joint that's barely visible most of the time.
Looks and feels like a solid repair.
Sadly no in process shots, did ask but it didn't happen.
So it's difficult to know the extent of the rust, although more welding than anticipated was carried out it didn't appear that the rust had spread to far along the joint.
So I only have before and after shots
Their respray quote again was very expensive starting at £12K and £15K for a bare metal respray.
Bit too expensive for me despite my love for the car
I'll just keep looking and getting quotes
Thanks for looking
I now have a garage
Thanks for looking
Another year , another MOT. Yippee!
Not bad for 32 years old.
Slight trailing nearside brake that needs sorting, been stood too long rather than driven this year, but apart from that a clean bill of health.
Hopefully get some more work done on it over the winter rather than DIY around the house.
Looks just great. Seeing yours reminds me just how far I've yet to go. Fabulous.
Looks great, well done on the pass!
Rover 220 Coupe Turbo
Rover 220 Coupe Turbo Racer
Plodder said;
"Their respray quote again was very expensive starting at £12K and £15K for a bare metal respray.
Thanks for looking"
Paint cost fluctuate according to the depth of the classic car owners pocket!
I went for a quote to paint my hatch gutter to BCC Restorations just North of Bristol in Thornbury. They specialise in Jag' XK's by the way, full bare metal respray start at £20k
I got some nice people to do it in Longwell Green [ so walking distance ] for 325! so hopefully success
They had a lot of difficulty getting the loom out etc, but it was all put back together as was much to my relief!
Thanks for looking"
Been unable to fix the dragging rear brake so have invested in a replacement calliper.
Just need to swap it over now
They are not worth stripping down any longer the needle rollers for the hand brake cam turn to mush and the two part piston seizes up. Now 50 quid used to be 160 from a dealer and needed stripping down!
Just a small update.
Finally managed to fit the new rear near side caliper that was identified as an issue on the the MOT.
Only taken 4 months to find the time between the DIY, taxi driving, cold weather and the rain.
So off with the old, that was fitted back in 2002, and on with the new!
The MOT station said it was slightly dragging, but not significant. Well with the wheel off I couldn't turn the disc by hand
Interestingly after replacing the rear caliper both nearside discs get warmer than the offside discs after a trip out, not sure why?
So the only original caliper is the near side front, I might just replace that for the sheer hell of it
Next up a cam belt change, but still a long list of other improvements needed
Slowly getting more space in the garage to swing a spanner , so I'm hoping I'll have enough room to store and do the headliner later this year.
.The MOT station said it was slightly dragging, but not significant. Well with the wheel off I couldn't turn the disc by hand
Well finally managed to get the car off the ramps just in time for the next MOT
Should have done this over the winter rather than during the summer/show season
Replaced the brake reaction bar bushes and got the reaction bars repainted at the same time . Took a bit of time to get the fixing holes in the bars aligned with the lower suspension arm (see separate post).
https://rover200.org.uk/forums/topic/16346
But all done now
I think the bushes on the lower suspension arms might also need upgrading but happy to complete the job
Trimmed the lip off the poly bushes to allow them to fit properly in the front sub frame and fitted them the opposite way round to the o.e. rubber bushes as recommended.
Also cleaned the plastic sump guard of 30+ years of grime. Used an awful lot of tar cleaner and tooth paste but it came up pretty good.
All just in time for the MOT next week.
I've done about 50 miles since the last MOT, which is rubbish , will make sure I do any work needed over the winter this time and enjoy next years shows
But all done now
