Welded roll bar bracket
Well was under a different car today and was removing roll bar ,well it was welded to the chassis !!!!! bodge job
Re: Welded roll bar bracket
Is that Welding ?
Looks like a flock of Seagulls have shat on it
Stan Thomas
I have a saying regarding classic and vintage cars:
It's not the car thats at fault, it's the so-called "expert" that had it before you!
P.S.
I'm currently restoring a 1931 Daimler with a Knight sleeve valve engine. It's called a" Knight" because if you have one you don't sleep at (K)night.
P.S.
- 220 GSi turbo
I know of two cars that it has happened on, and in both cases it was not rust. The ARB bracket bolts through the chassis box section to a threaded strip of steel which is not particularly wide and over a period of time it exerts enough force on the chassis section to break out of it. It's a fairly straightforward repair to a competent welder (although definitely advisable to remove the fuel tank) and can be restored to factory spec leaving very little sign that a repair has taken place.
Looks like the one in your photo was a typical 'MoT repair'. Poor solution (welding the bracket directly to the body) and poor execution (rubbish welding. Or maybe even Tiger Seal
Tiger sesl
its not that good *laughs* yes I've been looking on coupe fourn on a car rebuild last night and there another one with the same issue quite common they say , racers must beef there's up .
That picture is hurting my eyes
Common problem, the ‘L shaped’ bracket that holds the ARB to the chassis weakens over time due to rust between the two surfaces.
It’s a straight forward repair even for an average welder, but this method is just totally wrong!
Rover 220 Coupe Turbo
Rover 220 Coupe Turbo Racer
Over the years I've seen silly repairs but I never get the bird shite welding .James3990 wrote: ↑Sun Mar 10, 2024 9:18 am That picture is hurting my eyes![]()
I restored a healey sprite in the 80s and that's still going full sills and front chassis legs gas welded you don't get bird shite .
So you racing boys must upgrade yours if they are prone to breaking .
