Tried the key in the drivers door thing again today and still immobilised.
Looks like a new programmed key fob it is!
I have one but it has never worked, I always used the other one which did (now lost).
Please can someone tell me where the 5AS ECU is located?
Or do instructions come with the ordering of the new fob service?
Immobilised
RetroRacer
Re: Immobilised
1994 L reg 216 SLi
Re: Immobilised
It is right under the driver side dash upper bulkhead inline with the fuse box , it's black with two plastics nuts 10mm socket and one or two white plugs basically stand on yer head with a lamp and your thereRetroRacer wrote: ↑Tue Jan 21, 2025 4:58 pm Tried the key in the drivers door thing again today and still immobilised.
Re: Immobilised
AS Chris says, but on an 1994 car, it will look like the box in the picture, but have a large letter "L" on it, and no white connector
RetroRacer
Re: Immobilised
Thank you so much for this!961tat wrote: ↑Tue Jan 21, 2025 9:48 pmIt is right under the driver side dash upper bulkhead inline with the fuse box , it's black with two plastics nuts 10mm socket and one or two white plugs basically stand on yer head with a lamp and your thereRetroRacer wrote: ↑Tue Jan 21, 2025 4:58 pm Tried the key in the drivers door thing again today and still immobilised.
Cant believe im only just seeing this now and have got it out... 5 months later!!!
1994 L reg 216 SLi
