Rust in Turrets
howes5rz
Rust in Turrets
Post by howes5rz »
I have rust in the vertical part of one of the turrets of my 98 coupe.
Is rust in the vertical part of the turret normal? Are there repair panels available, or if not,
is there a template or recommended area/size for this to be?
Re: Rust in Turrets
Post by itcaptainslow »
A picture would be helpful to determine if it needs repair :)
Re: Rust in Turrets
Post by 961tat »
howes5rz wrote: ↑Mon Feb 17, 2025 1:02 pm I have rust in the vertical part of one of the turrets of my 98 coupe.
Some rust others don't if you get a picture I can send you section to weld in if needed .
howes5rz
Re: Rust in Turrets
Post by howes5rz »
Thanks for replies. Garage has said it will need doing for MOT. I was looking for guidance for my welder. Still learning how to use Forum, so hopefully this works!
Re: Rust in Turrets
Post by 961tat »
Of I was doing that repair I would take out shocker and spring and plate in the turret , weld from the inside then weld the two holes from outside and grind flush and fill .
