681 Radio/Cassette
BlairHobson
681 Radio/Cassette
Post by BlairHobson »
I have the above in my Concerto. Up until now I've never used it but having recently got a cassette I'd like to try it. I pushed the on/off button and a light came on behind the large volume button but the display didn't light up and the cassette didn't play however much i pressed the mode button. Do I have to key in the code before the display lights up or is it knackered?
Montegoman
Re: 681 Radio/Cassette
Post by Montegoman »
It should come up with a C if you need to input the code. Does the radio work?
BlairHobson
No sound at all, just the back light behind the volume button.
Montegoman
If it is not showing anything on the display, I would guess that the display has failed. It should show a C if it is asking for the code to be inputted.
Post by StubbornPatriot »
I suppose it could be possible that it is asking for the code but because the display has failed you can't see the -C-. If you know the code, it is probably worth trying to enter it and see if that is the problem.
BlairHobson
Yes, I thought that as well, so tried it, but it didn't work! Knackered is I think the phrase!
BlairHobson
Right, took the radio, an R652, out of the 216 that's off the road and stuck it in the Honda. Bingo! The lights come on and I get the - C - on the display. Trouble is i have no code!
BlairHobson
Sorted!!
The R652 worked and we can now listen to The Seekers on our way to Pershore (whether they like them or not!!).
216CAB
Post by 216CAB »
I'm intrigued as you said you didn't have the radio code; how did you then manage to get it to work?
The Seekers get a big thumbs up from me! 🙂
Post by Topcat Tomcat »
[quote
[/quote]
I won't object to them. I'm just about old enough to remember seeing their last concert on the tv.
If you're unlucky, might see you again......provided I don't drop off!
